Tunnel Insulation Collar
Old Aug 28, 2013 | 10:32 AM
wisoutlaw's Avatar
wisoutlaw
Default Tunnel Insulation Collar
Has anybody used that curved foam collar that wedges between the bellhousing and the tunnel? Do they work? Did you glue it to the b/h or the tunnel? We're getting close to putting the body back on my 69 convertible and now would be the time to install that. Otherwise for the rest of the heat and sound proofing we're using dynamat.
Old Aug 28, 2013 | 10:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The collar was factory for several years. They work.
Old Aug 28, 2013 | 11:00 AM
20mercury's Avatar
20mercury
Default foam collar
With the transmission out, I put in the foam collar, and the aluminum foil covered insulated transmission tunnel and the foil covered plastic bubble insulation (under the carpet inside) from Lowes. You get a roll of the Lowes stuff and cut to fit, cheaper than dynamite in my opinion.
Also check for air leaks in the firewall.
I put Automotive GOOP on the top and bottom edge of the foam collar and just wedged it up in there.
All of this made a big difference in the **** pit heat. Hard to tell if the foam collar by itself makes a big difference. I think if you are going to do something to control the cockpit heat, might as well do everything.
Hope this helps.
Old Aug 28, 2013 | 11:23 AM
MrJlr's Avatar
MrJlr
I didn't glue mine...just wedged it in. It hasn't moved at all in over a year
It helps for sure
Old Aug 28, 2013 | 11:32 AM
Alan 71's Avatar
Alan 71
Hi wo,
I too found that the fiberglass tunnel compresses the foam collar enough to hold it in place without any adhesive.
It's easier to position it as the body is lowered back on the frame but MrJ is right, you can wedge it into position after the body is back on too.
Regards,
Alan
Old Aug 28, 2013 | 11:34 AM
REELAV8R's Avatar
REELAV8R
Mine is glued to the tunnel. Still stock. It keeps tunnel heat down. At least mine doesn't get hot.
Old Aug 28, 2013 | 01:33 PM
jcloving's Avatar
jcloving
It works. Get one, they're cheap.
My original was still in place although it was far back. I replaced mine when I redid the tranny/clutch.
Old Aug 28, 2013 | 02:44 PM
7T1vette's Avatar
7T1vette
It doesn't need glue, if the trans is already in place. But, if not, you need a little to just keep it in place till trans is installed.
I didn't think of it at the time, when I installed mine, but it might have been a good idea to wrap that 'puppie' in some aluminum foil (to seal it and protect it) before installation. I doubt that the foam/plastic collar will live very long in that environment "as is".
From what I could tell from the AIM and from 'logic', that collar should be installed immediately behind where the cooler lines enter the trans case.
Old Aug 28, 2013 | 03:33 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by 7T1vette
...From what I could tell from the AIM and from 'logic', that collar should be installed immediately behind where the cooler lines enter the trans case...
Close enough.
Old Sep 1, 2013 | 03:16 AM
Ricknhis69's Avatar
Ricknhis69
factory glued it to the bell housing. 2 1/4' back from the edge of the bell housing if I recall correctly from my research. Just had mine installed this year, definitely made a difference. Quite a bit cooler without dynomat or any special insulation.
Old Sep 1, 2013 | 10:19 AM
gcusmano74's Avatar
gcusmano74
Yes. The foam collar helps, the tunnel insulation helps. On my '74, the tunnel insulation is retained by four special clips that are riveted to the body and pierce the insulation. I was able to just snake the foam collar over the (manual) trans after everything else was installed.
I also got some stick on reflective insulation (from Jeg's) and placed it in front of and to each side of the tunnel insulation.
Every little bit helps.
To Tunnel Insulation Collar
