Dial indicator and Runout
Old Sep 4, 2013 | 09:28 AM
20mercury's Avatar
20mercury
Default Yep, works for me.
Originally Posted by 401KVette
But since I drained the master cylinder and filled with fresh fluid, then flushed the lines, then refilled, I'm not sure how would be the best way to bleed the system with the calipers on. I don't have a pressure bleeder so I was going to try the two manway of pumping the pedal.
Yep, this is the way I do it, only difference is instead of "two manway", my wife pumps the brake pedal slow and steady and I bleed the brakes!, LOL's!
