tire rubs
I checked the wheel clearances and there seems to be plenty of room on the right front tire, but the left front hits the front lower wheel well when steering to the right only.
I've only had her for a month, have put about 750 miles on her, and she has always driven perfectly straight down the road. The tires that were on it were 215/70-15s and didn't rub.
Where should I start with this? It bothers me that the left side rubs and the right side doesn't--makes me think something is tweaked and out of whack.
What should I check first? BEFORE I get smaller tires!
Thanks,
Rich
Since it drove straight before and the old tires were very evenly worn, no cupping or anything, Could the body be misaligned on the frame? Is that something I could determine and fix by myself?
The 215-70 that was on your car is the modern equivalent size of the F70 that was originally on your when new.
While the 255-60 tire is about the same height as the original, it's MUCH wider.
It will rub on some cars and not others. If nothing else, it might just depend on exactly how straight the body was set on the frame.
Just exactly where does the tire rub? When the std tire was changed to the 255-60 I believe the front fender lips were trimmed on the production line.
Regards,
Alan
Regards,
Alan
Is it possible to loosen body mounts and slightly adjust body position on frame?
Roger
With the steering wheel 1-1/2 turns left the left front tire also rubs the rear of the wheelwell as in this picture....
The right front tire has clearance all around, and looks like it will be ok with suspension travel, too. Looking along both sides of the car from the front, it's hard to tell, but I get the impression that both left side tires stick out farther than the right side tires.compare the two photos....
So, I'm thinking my options here are:
1. put the spare on the left front, bring the other wheel to the alignment shop and see what they can figure out
2. Trim away at the body,
3. Get smaller tires
4. Is the body out of alignment?
Any other ideas? I'm leaning towards #1 since I would like to have an alignment done anyway, and I think there is some play on the right front.
What do you think?
Mechanic said he has seen this a lot on C3s and there used to be a "kit" to fix this problem.
Anybody here of this?
Thanks, Rich
I'm glad you've been able to get to the bottom of this.
No, I've never heard of there being a "kit" to fix this.
Maybe urban or suburban "mechanic's legend"?
Regards,
Alan
Thinking he was just razzin' me. Then he went right to the cradle and showed me the welds and explained it. It needs a new idler arm, too.
As far as the kit, he said he has done two or three of these C3s with cracks and welded them up. He said it is pretty tough to get it exactly perfect with the engine, and front end and all in place, but it is close. The aft lower left end is off by about 1/8-3/16" and to compensate, the left assembly is pushed outboard just enough to cause a problem with wider tires. Kenny told me that the welds were good and looked solid. It drives perfectly straight and handles fine.
Somebody came to Kenny with this kit about 5 years ago. He said it came with a template and braces that he had to do a little cutting and drilling and bolted it all up. And then he followed it up with some welds.
So knowing that the 215/70s don't rub, And they are very close in profile size(215x70%=150.5 and 255x60#=153) only 2.5mm off, they should fill out the wheelwell and look pretty close in size fore and aft.
Thanks for the photo, Roco. How do you like those Coopers? I went with the BFGs--had a set on my first car--'67 Chevelle back in 1980!
I guess the question I have now, How common are these cracks? And how do they affect the value?
