cracked intake manifold huge problem?
Old Sep 8, 2013 | 05:50 PM
Rubetech's Avatar
Rubetech
Default cracked intake manifold huge problem?
So I noticed a crack in the intake manifold today. I am wondering If it is a huge problem and should not be driven until fixed or just something I need to watch until I rebuild the carb and then I can replace it then?
I would appreciate as much info as possible on this, if you have had this issue and what you did to address it.
Thanks in advance
Brent
Old Sep 8, 2013 | 06:15 PM
DUB's Avatar
DUB
Replace the intake if possible...especially if it is factory. Should not be a big issue in finding one.
The other option is having it welded. If it is aluminum...it can be welded...OR...you can look up "Muggy Weld" and watch the videos on repairing it yourself if you want to give that a try...depending on you skill level and equipment available. I use Muggy Weld products and they work great.
DUB
Old Sep 8, 2013 | 07:50 PM
7T1vette's Avatar
7T1vette
How the heck did that happen!? It looks like it has blown out from the inside, but there's no significant pressure in there.
If the surface of the broken area is clean (not corroded, etc.), you should be able to weld it up. If the material is 'rotten' [for whatever reason], pitch it.
Old Sep 8, 2013 | 09:27 PM
scottyp99's Avatar
scottyp99
Are you sure it's a crack? Maybe you could spray some carb cleaner on it when it's running, and see if it's getting through. If the rpm rises, you've got a vacuum leak and it should be repaired or replaced. If you're going to be rebuilding the carb soon, I suppose you could smear some JB Weld on it and see what happens. You can find Edelbrock 2101 intakes on ebay and craigslist for, like 50 bucks if you keep your eyes open for one.
Scott
Old Sep 8, 2013 | 09:28 PM
oldalaskaman's Avatar
oldalaskaman
if its not leaking, run it till you get another, it wont get any better and as prev. stated they are cheap
Old Sep 8, 2013 | 11:29 PM
7t9l82's Avatar
7t9l82
was that intake ever on a boat, maybe salt water?
Old Sep 9, 2013 | 02:00 AM
oldalaskaman
those northeast cars get like that
Old Sep 9, 2013 | 07:33 AM
LS4 PILOT's Avatar
LS4 PILOT
at some point Chevy used a version of the old iron intake cast in aluminum , maybe 78 or 79 , think one was on my 79 l82. ,if that is what you have.
These should be on ebay , or corvette junkyards fairly cheap . Probally just a poor casting that finally gave up.
Old Sep 9, 2013 | 09:24 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
Kinda looks like a casting flaw...?...good luck!
Old Sep 9, 2013 | 11:59 AM
7T1vette's Avatar
7T1vette
Actually, with the edges of the crack being at different heights, it looks like something put some really high compression-stress loads on the area below that crack...
Old Sep 9, 2013 | 12:04 PM
cv67's Avatar
cv67
St. Jude Donor '05
Looks like flaking paint to me....casting flaw at worst.
If it was a crack believe me youd know.
Old Sep 9, 2013 | 12:15 PM
7T1vette's Avatar
7T1vette
Ooooo.... That could be it. Maybe the intake was painted with a ceramic aluminum colored paint. Good catch!
To the OP-- See if you can get a small tool in under the top edge of that "crack" and lift it off.
Old Sep 9, 2013 | 07:22 PM
my 76 ray's Avatar
my 76 ray
I thought peeling paint as well.
Old Sep 10, 2013 | 11:28 AM
Indiancreek's Avatar
Indiancreek
[QUOTE=scottyp99;1584872770]Are you sure it's a crack?
sand that down with a wheel or a sanding stick and make sure it's a crack. Looks like a casting line to me.
Old Sep 11, 2013 | 04:17 PM
KenSny's Avatar
KenSny
my vote is for peeling paint. Paint stops and bare metal starts.
Old Sep 12, 2013 | 07:21 PM
Rubetech's Avatar
Rubetech
The intake was never on a boat, it's all origional matching mumbers, it is the origional intake never taken off the car. there isn't any fluid or anything spraying out or leaking. It would be gas that would come out right not oil? What would I notice the car doing if it was a crack, would it not run, would it be blowing out gas and or oil, would it be running like crap? Is it safe to drive in that condition?
Old Sep 12, 2013 | 07:32 PM
hugie82's Avatar
hugie82
If its on the intake runner, I would drill small hole at the end of the crack and JB Weld it. Until you find a replacement....
The worst thing that could happen is that cylinder running lean and possibly over heating that cylinder.
To cracked intake manifold huge problem?
Old Sep 12, 2013 | 07:43 PM
Rubetech's Avatar
Rubetech
so the Edelbrock 2101 intake is the the intake that is the low profile that fits under the hood? Is that about the only elderbrock that fits that application, or just the lowest cost one? I have been having a hard time finding specifications on height when I have been shopping for intakes are there others that fit? is the Edelbrock 2101 intake going to give me an increase in preformance over stock?
Old Sep 12, 2013 | 11:43 PM
garygnu's Avatar
garygnu
you should have a spread bore carb,bigger ventures in the rear .so you need a spread bore intake if your intake is cracked.a elderbrock intake should add 5-10 hp.weiand has a intake that fits also .
Old Sep 12, 2013 | 11:48 PM
68/70Vette's Avatar
68/70Vette
I've never seen anything like this. Maybe take a small Dremel tool and grind out the crack to see what you're working with. If the crack is really deep into the aluminum casting, I like the suggestion to drill a small hole at each end of the crack. This is to stop it spreading. If its deep into the aluminum manifold, I'd think you can have it heli-arced (TIG) without removing the manifold.
Actually, if you grind out the crack, etc, a cheap Charlie fix may be to seal up the crack with gas resistant RTV. The pressure difference between the inside of the manifold and the outside will never be more than about 10 pounds per square inch. so sealing is not difficult.
