79 corvette spedometer jumping
Old Sep 26, 2013 | 03:36 PM
bballboy06's Avatar
bballboy06
Default 79 corvette spedometer jumping
79 corvette L-82 when driving the spedometer jumps up and down..
i have replaced the spedo cable, not sure where to go from here.
Thanks for all of the info
Old Sep 26, 2013 | 03:42 PM
MelWff's Avatar
MelWff
When you replaced the cable, did you check the condition of the driven gear in the trani?
Old Sep 26, 2013 | 04:00 PM
bballboy06's Avatar
bballboy06
No i did not is that located inside the location where the spedo cable connects?
Old Sep 26, 2013 | 04:50 PM
MelWff's Avatar
MelWff
yes it is
Old Sep 26, 2013 | 05:18 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Solved my erratic speedo.
Old Sep 26, 2013 | 05:45 PM
DUB's Avatar
DUB
Being a 1979....and if it still has a cruise control traducer....the transducer can be binding also.
Also...when a new cable was installed...GM had an aluminum retainer that clipped onto the cable housing to hold the curve radius of the cable. This was so it would not be allowed to be possibly bent into a tighter radius...and cause the cable to bounce due to binding.
Make sure the cable is away and secured from all heat sources.
DUB
To 79 corvette spedometer jumping
