bbc headers
Old Sep 28, 2013 | 08:36 PM
mvette76's Avatar
mvette76
Default bbc headers
for all you bbc guys what headers are you running pros and cons with fitment and performance? thanks for any input
Old Sep 28, 2013 | 10:32 PM
Les's Avatar
Les
I've had Hedmans for over 20 years- 2" primaries w/ a 3" collector. I did send them to Jet Hot to get coated after a couple of years. I'd buy them new with the heat coating, whatever brand you choose. The paint will never hold up and then rust will set in. It's worth the extra $ up front IMO. I had to make a small dimple on one primary tube on the passenger side at the frame because it would tap the frame sometimes at idle. Nobody has ever even noticed it. You may not have that problem at all. I haven't seen it firsthand but I've read that the Hookers give less ground clearance than the Hedmans. The only thing I've ever scraped is higher than normal speed bumps- you just need to slow down a bit more for them. The performance gains far outweigh any small negatives.
Old Sep 29, 2013 | 12:25 AM
ddawson's Avatar
ddawson
Hedmans here too.
I had them coated as the one they sell you is only coated on the outside.
As for fitment they just barley hit the passenger side frame so they have to be dented to make a little room..
Old Sep 29, 2013 | 05:19 AM
roscobbc's Avatar
roscobbc
Had Heman 1 7/8" id's on mine for 7 or 8 years - they fitted well and although close to chassis on passenger side and steering box on drivers side they didn't touch. Good road clearance - however due to that collectors are a little close to floor. If the car is used regularly, only put in garage when engine and exhaust system fully warmed through then corrosion should be an issue.
I recently changed to Hooker 2 1/8" Super Comps. Again fitment was fine with not touching, but I used new poly engine mounts to be sure of alignment. Collectors hang down VERY low and connected exhaust at front of car is too, so ground clearance is a real issue - even more so if the car is lowered. These headers are ceramic coated. The real benefit is not so much prevention of corrosion, but heat insulation (they run cooler) and noise insulation (they run quieter without the usual 'ticking' sound from tubular headers) - as a bonus they look good too
Old Sep 29, 2013 | 08:59 AM
roger3's Avatar
roger3
I have hooker headers with sidepipes. I bought them used from a fellow with a 70 vette. He had no fitment issues. I had to dent them in about 6 locations to fit my car so each car could be a little different. Sidepipes eliminates the cabin heat issue and I think they look really good.
I dynoed my engine with regular headers and with side pipe headers. If I'm remembering correctly side headers lost 5hp.
Roger
Old Sep 29, 2013 | 10:40 AM
mvette76's Avatar
mvette76
what part# for the hedmans they have 3 that all look the same? coated 2" primary 3" collecter
Old Sep 29, 2013 | 11:22 AM
DRIVESHAFT's Avatar
DRIVESHAFT
68096, unless you're worried about air tubes or emissions.
Old Sep 29, 2013 | 12:05 PM
mvette76's Avatar
mvette76
thanks
Old Sep 29, 2013 | 12:20 PM
ddawson's Avatar
ddawson
I went with the 68090 and had them coated inside and out. In the end the cost was the same as the 68096 and I got two thermal barriers.
Old Sep 29, 2013 | 12:46 PM
zwede's Avatar
zwede
I have Hooker supercomps, the 1 7/8" primary version. Needed a few dimples. Good ground clearance. The hooker applied ceramic coating was trash, flaked off in a few years. Took them off, scuffed them and used some of that new super-duper silver header paint. To my surprise it held up. It really was super-duper.
Old Oct 1, 2013 | 09:00 PM
auavette's Avatar
auavette
Jethot hookers with side pipes, easy fit, bolt on with no problem
Old Oct 1, 2013 | 09:10 PM
Super6's Avatar
Super6
Bought my Hooker sidemounts directly from Jet-Hot. Really good coating...11 years old. 2 1/8" primaries, no fitment issues.
Old Oct 24, 2013 | 05:21 PM
Stu's81's Avatar
Stu's81
Does it matter if your heads a D-shaped ports versus oval?
Old Oct 24, 2013 | 05:48 PM
zwede's Avatar
zwede
No. A head port that is a bit smaller than the header tube is good. It helps fight reversion.
Old Oct 24, 2013 | 07:24 PM
Tudz's Avatar
Tudz
I just recently put a set of Hooker 1 7/8" SuperComp headers on my 71 with a ZZ454. I spent a while considering the 2" Hedmans, which are a hell of a lot cheaper, but decided 2" was too big for my needs so forked over the extra for the Hookers largely because no one else makes anything 1 7/8" or smaller for BB C3's.
So far so good. Getting it tuned this weekend so we'll see how it goes after that, it's leaning out too much under WOT at the moment, so I haven't pushed them yet.
Old Oct 24, 2013 | 07:27 PM
Tudz's Avatar
Tudz
I'll also say, they did lower the car slightly, but not excessively, the biggest thing is the flange on the Hooker's points downward (so the bolt is at the bottom). The pipes themselves are maybe 1/4" lower than before, but the flange is another 1/2" or so lower than that. Haven't grounded them out yet, but it won't surprise me if I do at some point, lol.
Old Oct 24, 2013 | 08:31 PM
Rebelrob's Avatar
Rebelrob
Hedman customer here. They were coated when I purchased them.
Depending on your heads OEM, or after market, you typically have to dent the #3 tube to clear steering box if your exhaust ports are raised.
To bbc headers
Old Oct 24, 2013 | 08:42 PM
Stu's81's Avatar
Stu's81
When you dent them does the coating come off?
Old Oct 24, 2013 | 09:31 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've got 2 sets of black Hooker sidemounts; older ones reserved for dyno duty, newer ones for running. Periodic re-painting has yielded good results over the years, but must be properly done. In any event I do plan on having JetHot do the running set someday. ...in matte black, of course. 427, FWIW.
Old Oct 25, 2013 | 10:03 PM
RickyBerg's Avatar
RickyBerg
Hooker Supercomp 2-1/8".
Good for performance but full length and 3,5" collectors not so good for ground clearence..
