1981/L81 - ASM valve?
Old Sep 28, 2013 | 10:13 PM
SGAL1's Avatar
SGAL1
Default 1981/L81 - Vac control valve?
Please excuse my ignorance....but I removed the air cleaner housing today,
because my 81 is running rough and stalled today and I was just checking around for a vacuum leak,
and I noticed this broken valve.
My AIM manual calls it an ASM valve?
Ecklers calls that housing a thermostat housing w/ emissions ports so I'm guessing these are some sort of emissions valves?
Can anyone tell me a couple of things....like
1) What is it and what does it do?
2) Do I need to drain the radiator when I swap this part out?
3) Is this the replacement? http://www.ecklerscorvette.com/corve...roduct_Related
Thanks for your input.
Old Sep 28, 2013 | 11:47 PM
namvet6869's Avatar
namvet6869
you would need to drain radiator low enough to replace valve. mine is set up where bottom hose of switch connects to the "T" at bottom of carb and other to the heat riser. when engine is cold valve has vacuum to the heat riser and closes it. when engine reaches op temp valve closes and heat riser opens. since you have no vacuum running to valve, you should not have vacuum leak. my heat riser does not work so hose is plugged at riser. hope I am right on this
Old Sep 29, 2013 | 09:38 AM
SGAL1's Avatar
SGAL1
Thanks for the info. I see there are a couple of different types for sale at Ecklers.
Can anyone tell me what type of sealer I should use to seal the threads when I replace the broken valve?
Old Sep 29, 2013 | 09:59 AM
Street Rat's Avatar
Street Rat
You can use teflon tape, teflon sealer, or Permatex #2 on the threads of the part.
Old Sep 29, 2013 | 11:37 AM
SGAL1's Avatar
SGAL1
I have Teflon tape in my toolbox...Thanks for that.
To 1981/L81 - ASM valve?
