Falling Flat
Old Oct 2, 2013 | 02:15 PM
kend47's Avatar
kend47
Default Falling Flat
My 77 Vette falls flat on its face when I punch it hard. Had the Quadrajet carb rebuilt and timing checked. This happens when engine is cold or hot. It acts like it is starving for fuel.
Old Oct 2, 2013 | 02:16 PM
1977L48's Avatar
1977L48
check the accelerator pump, take the air cleaner off and open the throttle and see if fuel in squirted into the front 2 barrels
Old Oct 3, 2013 | 12:35 AM
Aussie79's Avatar
Aussie79
Mine does it too, I have been told it is a clogged filter on the pickup in the tank, makes sense so I am pulling mine out this weekend to have a look, suggest you do the same.
Cheers, Dennis.
Old Oct 3, 2013 | 10:45 AM
REELAV8R's Avatar
REELAV8R
There are several reasons it may be bogging. Do a search here and you'll find plenty of info. A clogged pickup tube in the tank is not likely your issue.
Old Oct 3, 2013 | 10:52 AM
MelWff's Avatar
MelWff
Default Fuel pressure test
Cheers, Dennis.
Before you waste your time, have you done a fuel pressure test?
Old Oct 3, 2013 | 10:57 AM
MelWff's Avatar
MelWff
Default Bog
In addition to the primary accelerator pump it could be a low float level or the secondary air valve is not correctly adjusted.
Old Oct 3, 2013 | 11:05 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Check that your choke rod is not interfering with anything and the valve is opening with the air cleaner on.
Old Oct 3, 2013 | 05:37 PM
kend47's Avatar
kend47
The gas tank was replaced about a year ago. I will check the accelerator pump. Did a search for info and came up empty. Thanks all for help.
Old Oct 3, 2013 | 08:08 PM
7t9l82's Avatar
7t9l82
the accelerator pump may function but not squirt enough fuel. you may need to adjust the secondary air door.
Old Oct 3, 2013 | 08:40 PM
spinadog's Avatar
spinadog
I would define 'flat on it's face'. If you punch it and it coughs before it builds speed = accelerator pump is weak or not working. If it simply does not have the 'go' it should and appears to starve, then that suggests fuel flow issues or secondaries as pointed out.
To Falling Flat
