New Duntov Diff and a big problem...
Old Oct 2, 2013 | 09:23 PM
Fredscott's Avatar
Fredscott
Default New Duntov Diff and a big problem...
I just received a new 3.54 differential from Duntov....2 weeks with build and shipping. This is going in my 82.
PROBLEM....side yokes on new diff do not match the side yokes on the old one, they are smaller and I can't install the U-joints (cups are too big!).
I called and left a message and will speak to them tomorrow, but I'm wondering if anyone has ever heard of a U-joint with 2 different size cups? It's a stretch, but I'm hoping otherwise, this is gonna have to be shipped back and started over....major bummer this time of year in Central New York.
Anybody have any thoughts?
Fred
Old Oct 2, 2013 | 09:28 PM
Kid Vette's Avatar
Kid Vette
80 and 81 manual trans and all 82s use 1350 u-joints. 80 and 81 automatics use 1330s.
Old Oct 2, 2013 | 09:50 PM
Fredscott's Avatar
Fredscott
they didn't build this with 1350's...they are smaller. I'm hoping I can get a conversion joint to make this work....I didn't even know they made them!
Old Oct 2, 2013 | 10:45 PM
Arkyvette's Avatar
Arkyvette
send it back. they should know about the 82 u joints. you just need the manual version.
Old Oct 2, 2013 | 10:56 PM
zwede's Avatar
zwede
Should have done a search on the forum before using them...
Old Oct 2, 2013 | 11:55 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Yes You could probably use a conversion u-joint. But one would think that it would only be as strong as its weakest side ( the small one). And considering that the U-joints are generally the weakest part of the early Dana 44's You may not want to go this route. At this point we might figure that You might of got an exchange rear and not your original back. By looking at the serial numbers on the bottom one can figure that out. One Option would be to just change out the Yoke Shafts for the correct ones.
Old Oct 3, 2013 | 10:19 PM
tracdogg2's Avatar
tracdogg2
Do not use a conversion u-joint on the halfshaft. It will not have the body strength.
Apparently something has changed over there, again, because I am getting flooded with re-doing their rebuilds. I just had a man bring me a pair of trailing arms that were just rebuilt by the afore mentioned company. Both arms are bent, the caliper brackets are bent, the bearings are loose, and the cheap lockwashers were all spread open.
They just lost a customer last saturday. A fairly well known Corvette restoration company in Plano, Texas. Not that I had anything to do with it, I was just standing in the right place at the right time.
Mike
Old Oct 4, 2013 | 08:04 AM
groovyjay's Avatar
groovyjay
Duntov...
To New Duntov Diff and a big problem...
