Upper Control Arm Shaft
Old Oct 3, 2013 | 06:31 AM
mikep3's Avatar
mikep3
Default Upper Control Arm Shaft
I am going to replace my upper control arm bushings with Moog parts. This kit with new offset shaft was offered and I am wanting to know if there is a real advantage to this shaft. Plus how do you install the offset, up or down?
Advance Auto/Moog shaft kit:
http://shop.advanceautoparts.com/web...arms+%26+parts
Old Oct 3, 2013 | 11:16 AM
MelWff's Avatar
MelWff
All you need are the bushings. The offset shaft is for racing requiring extreme camber angles or other issues like a bent frame.
Old Oct 3, 2013 | 11:22 AM
TWINRAY's Avatar
TWINRAY
+ Search the web - you should be able to find, without too much difficulty, a $40 coupon code if you spend $100. I used them more than a few times in the past year. Add windshield wipers for another car or something if you need to reach the hundred.
Old Oct 3, 2013 | 06:26 PM
mikep3's Avatar
mikep3
Well, I am going for the Moog bushings only, as my car was tracking straight and had little tire ware.
Thanks for the advice.
Old Oct 3, 2013 | 06:46 PM
DUB's Avatar
DUB
The off-set shaft is to aid in compensating for frame/cradle collapse. I have not heard it being used just for racing...because I have installed numerous of these on street cars
The off-set shaft will give you more ability to align the car in the future...due to the cradle collapses in time...and when the upper shaft is touching the perch on the cradle ( no shims between the shaft and the cradle perch)...then you can not adjust the camber/caster any more. This off-set shaft will give you some more room to possibly obtain a good alignment.
If the off-set shaft is used and you still can not align it...like so many before you...the cradle will need to be stretched so shims can be installed and an alignment achieved.
DUB
To Upper Control Arm Shaft
