How does a Ujoint go bad?
Old Oct 6, 2013 | 10:01 AM
rafalc's Avatar
rafalc
Default How does a Ujoint go bad?
New non-greasable Spicers from Dannys Driveshafts. Have around 200 miles on them of flawless, quiet driving. Went to a car show yesterday, then an evening cruise, no problems. I back the car out of the garage this morning to hear clunk, clunk, clunk, clunk. Every time a clunk, it feels like the car has a hard time getting passed it and continuing to roll.
Defective Ujoint from the start?
Person who installed them messed it up?
Can over tightened U clamps squeeze the ujoint caps too much and cause failure?
But how can you go from good to bad overnight? Seize overnight?
Old Oct 6, 2013 | 03:11 PM
dochorsepower's Avatar
dochorsepower
Could be a faulty U-joint but it could be our old friend, a bad rear wheel bearing.
Old Oct 6, 2013 | 05:38 PM
rafalc's Avatar
rafalc
Good news is that I jumped to conclusion too soon, its not the ujoint. But can you F'n believe this.... seriously....
Balancing weights came lose. 1 small square got wedged into the cross section of the rotor and was hitting the brake pad sliding pin making the clunking sounds.
Both rear wheels had none of the weights left on them. Front wheels still got all of them stuck on. Taking the rears to STS tomorrow to complain and might decide to take the fronts back just in case as well.
Old Oct 6, 2013 | 06:59 PM
Ironcross's Avatar
Ironcross
There is no defective 'new' U Joints, just dumb installers that make them defective......
Old Oct 6, 2013 | 11:01 PM
mchar's Avatar
mchar
Please don't take the wheels back to the shop who screwed up....
loose weights??
Old Oct 6, 2013 | 11:10 PM
rafalc's Avatar
rafalc
loose weights??
They were not loose. I remember checking them myself before installing the wheel. Maybe the adhesive they use (the tape) did not hold up.
Its strange as the centripetal force from the wheel spinning actually pushes the weights towards the wheel, not away. Maybe heat affected the adhesive..... no idea.
Old Oct 7, 2013 | 12:15 PM
7T1vette's Avatar
7T1vette
The installer probably didn't use solvent to clean the surface before he [tried to] press them in place.
Old Oct 7, 2013 | 01:08 PM
rafalc's Avatar
rafalc
I took them back this morning, they said they do clean the wheels before sticking them on. I checked the wheels an hour later, 1 of the wheels the weight are already pealing, the installer did not stick them to a flat surface, instead they are stuck to a raised area, therefore not the entire back surface of the weight in making contact with the wheel. Im going back after work again..... this is ridiculous.
I will put some HVAC tape over them just in case.....
Old Oct 7, 2013 | 11:01 PM
7T1vette's Avatar
7T1vette
Ah, the modern-day workforce: they know everything...but can do nothing. And, many of them are completely unteachable.
Old Oct 8, 2013 | 01:17 AM
wombvette's Avatar
wombvette
Need some centripetal proof glue on them.
Old Oct 8, 2013 | 06:17 AM
lvmyvt76's Avatar
lvmyvt76
the duct tape will hold them, just ask RED GREEN about duct tape.
Old Oct 8, 2013 | 07:34 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
If the surface was flat in relation to the center then centrifugal force would hold the weight in place while the wheel was spinning. As it is, the weight is trying to find the sweet spot that is aligned with with the rotational center. So, it keeps creeping across the wheel until the adhesive releases. Good adhesive on a clean wheel with a flat surface matters a bunch!
Old Oct 8, 2013 | 08:42 AM
Rotonda's Avatar
Rotonda
HOW DOES A U-JOINT GO BAD?
By associating with bad people
Old Oct 8, 2013 | 09:09 AM
mrvette's Avatar
mrvette
For years now, all stick on weights on any vehicle of mine, make that mainly the vette, have been cleaned around the area, and RTV put all around the weight, to seal it on but good, all that double sided stick tape is not worth much, just like on the good old stick on bubble mirrors, they have to be surrounded with a bead of black RTV otherwise they tend to dry out and fall off....
To How does a Ujoint go bad?
