C3 Headlight Vibration
Old Oct 6, 2013 | 12:59 PM
Jump141's Avatar
Jump141
6th Gear
Default C3 Headlight Vibration
Hey guys...have a 75 and the right side headlights "bounce" due to vibration something fierce. The left side is solid...any suggestions to adjust/firm it up? Thanks a bunch! Rick
Old Oct 6, 2013 | 03:28 PM
Roco71's Avatar
Roco71
There is a bar on the side of the headlight bracket that has a screw and a nut on the end of it. When the headlights are up the screw should be adjusted so that it makes contact with the bracket holding it firm. I believe from the factory the screw where covered with a rubber cushion.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Oct 6, 2013 | 04:12 PM
Dave J's Avatar
Dave J
One of my cars came with the same symptom after I brought it home. It turns out the headlight frame was broken on one of the front "legs". The only cure for me was a new frame.
Old Oct 6, 2013 | 05:33 PM
Jump141's Avatar
Jump141
6th Gear
Thanks to you both...it definitely gives me a starting point. This thing has been a beast...everything you touch...you want to replace! LOL Does it ever end???
Old Oct 6, 2013 | 05:42 PM
Street Rat's Avatar
Street Rat
The short answer is no it doesn't end.
I've got some shaky headlights also. I haven't taken the time to post anything about them yet. Glad someone finally addressed this one.
Old Oct 6, 2013 | 05:47 PM
Alan 71's Avatar
Alan 71
Hi jump,
Roco's got the likely answer.
In addition the headlight mechanism needs to open completely to go into the 'lock' position. IF you can push the door closed without reaching underneath to release the mechanism the door isn't fully open.
If you can't move it it's likely Rocco's 'stop'.
Sometimes the rubber bumper has fallen off the bolt.
Good Luck!
Regards,
Alan
Old Oct 6, 2013 | 06:11 PM
Jump141's Avatar
Jump141
6th Gear
Thanks Rat and Alan...I saw a nice C3 one day right at dusk...and one headlight was doing the huckle-buck...I thought what a shame....now I have one doing the same thing! LOL
I can move the mechanism up/down a little...but its definitely firm enough that I can't push down by hand. I replaced both actuators and relays...could I have misadjusted something as well?
Old Oct 6, 2013 | 06:31 PM
Griff2002's Avatar
Griff2002
I had the same problem and doing this adjustment fixed it.
Old Oct 7, 2013 | 03:57 PM
Roco71's Avatar
Roco71
Originally Posted by Alan 71
Hi jump,
Good Luck!
Regards,
Alan
Alan,
Is the rubber bumper in your photo on the screw head the same rubber bumper used on the hood latch on a 71?
Thanks, Scott
Old Oct 7, 2013 | 05:29 PM
Jump141's Avatar
Jump141
6th Gear
Thanks all...you don't know how much your time and guidance is appreciated. I'm gonna go lay down in the garage floor and see if I can check it out! LOL
To C3 Headlight Vibration
