Cheap power window switches,..73
Old Oct 7, 2013 | 02:47 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Cheap power window switches,..73
On my 73, I'm about to replace my 3rd power window switch in the last 18 months; two on the drivers' side, now one on the passenger's. I've been using the $20~ repo sold from the usual catalog companies.
Changing the switches is a bit of a time-suck and I'd like to find a quality switch that will last a long time.
Would I be better off using a good used original? Or is there a better repo out there?
Please advise and thanks!
Old Oct 7, 2013 | 02:55 PM
MelWff's Avatar
MelWff
they probably all carry the same reproduction switch made in Taiwan. Anything else burning out prematurely like light bulbs?
Old Oct 7, 2013 | 03:15 PM
73, Dark Blue 454
Everything else, electrically, is fine. Once I replace the switch the windows work great for a while, then get balky, then quit altogether.
Old Oct 8, 2013 | 10:28 AM
jerryjoe's Avatar
jerryjoe
Default switches
I used my old ones ran them under a wire wheel on my bench grinder the three pins on the back now work great.
Old Oct 8, 2013 | 05:10 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I should have originals but boy they are high priced. http://willcoxcorvette.com/product_i...ducts_id=27890
Old Oct 8, 2013 | 06:19 PM
DUB's Avatar
DUB
I know your feeling. I run into this ALL the time on this stuff being made poorly. The main issue in the repo's are that the "bean counters" removed the molded plastic shield that GM originally installed to prevent crap from getting to the electrical circuit. Once "they" did that...all heck breaks loose and problems because due to the position of power window switches in the hand brake/shift console...it does not take much fuzz and lint and other stuff to get into the switches and begin to tarnish the contacts...and once a few arcs of current add more deformity to the terminals...there you go...heat build up and failure in the spring contacts and the way they make contact.
DUB
Old Oct 8, 2013 | 06:36 PM
stevelischynsky's Avatar
stevelischynsky
When you use the sw, do you hang onto the sw for a second longer once the window has reached it's stop? Once the motor has stalled, the current rises a lot which the sw may not be able to handle.
Steve L
73 coupe since new
Old Oct 8, 2013 | 06:55 PM
Rich's'78's Avatar
Rich's'78
Originally Posted by DUB
it does not take much fuzz and lint and other stuff to get into the switches and begin to tarnish the contacts...and once a few arcs of current add more deformity to the terminals...there you go...heat build up and failure in the spring contacts and the way they make contact.nDUB
I bought a new switch for my Vette from GM about 15 years ago and paid $60 (still in box). My '85 Pontiac's used to stop working every few years and removal and a good shot of WD40 would get it working. Re and Re was easy in that car. Just cleaned out the crap on the contacts.
Try getting an older swich and doing that. Willcox's price is in line.
Old Oct 8, 2013 | 09:55 PM
0Willcox Corvette
Former Vendor
Not to cut a sales.... but for years we would take the switches apart and fix them. You can get the bottom board out of the switch with ease. The outer housing is pot metal and you need to un-crimp the steak marks to do so. Once you get the switch open, inside you will find a set of contact points and in most cases you can file these with a point file, re-install, re-crimp and the switch is good as gold. (the contacts are closed either way by a lobe on the bottom of the flip lever in the switch).
Maybe I should re-visit the video camera and do one... Food for thought.
Willcox
Old Oct 8, 2013 | 10:20 PM
73, Dark Blue 454
I may try that on some original switches. I know they're not complicated but I didn't know they could taken apart and reassembled. Thanks Wilcox!
To Cheap power window switches,..73
