68 wiper grille fasteners
Old Oct 8, 2013 | 09:29 AM
carlisle61's Avatar
carlisle61
Default 68 wiper grille fasteners
I am in the process of putting back together the wiper grille, and need to find the fasteners that hold the end pieces to the top of the fenders. Does anyone know any vender who is selling them?
Old Oct 8, 2013 | 10:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Do you have the assembly instruction manual (AIM)? The AIM shows how the fender trim pieces install.
Old Oct 8, 2013 | 06:54 PM
DUB's Avatar
DUB
These are very touchy to install after the fact...and if you do not get them RIGHT...they will push off when you go to install the molding. PRECISE drilling and hole placement is required.
DUB
Old Oct 9, 2013 | 06:29 AM
carlisle61's Avatar
carlisle61
Thank you Easy Mike and DUB. Yes I have the AIM, and the holes for the fasteners are already in the fenders, but I could not find the original fasteners. Thanks again
Old Oct 10, 2013 | 06:03 PM
DUB's Avatar
DUB
The four (2 per side) of the special clips are available through about all of the major Corvette parts vendors...as what was posted by Easy Mike. As for the screws that secure the trim to the inside edge of the top hood surround...I will get back to you tomorrow on those. I have them but I do not know the Au-Ve-Co number right off the top of my head.
DUB
Old Oct 12, 2013 | 02:11 AM
Ironcross's Avatar
Ironcross
DUB
What are you calling a top hood surround?
This?
Old Oct 12, 2013 | 07:43 AM
carlisle61's Avatar
carlisle61
Yes, but just the side pieces. Not the long center pieces, I have the new clips for the long center.
Old Oct 12, 2013 | 04:21 PM
DUB's Avatar
DUB
The "top hood surround" is the panel that does just what it says. Surrounds the hood on the top. So it is the full panel that goes all the way around your hood and also has the holes for your headlights in it also....and is the panel that allows the two upper trims to be installed like you posted.
DUB
Old Oct 14, 2013 | 05:36 PM
DUB's Avatar
DUB
For what it is worth...the screws I use to secure the top trim to the top hood surround on the inside edge are Au-Ve_Co part number 9229. A very shallow/low height Phillips head so it will not conflict with the wiper door trim when closed....as long as the components are adjusted correctly.
DUB
To 68 wiper grille fasteners
