Paint code 82 collector edition
Old Oct 13, 2013 | 12:56 PM
tom podolec's Avatar
tom podolec
7th Gear
Default Paint code 82 collector edition
I have an area in my silver beige paint that requires some reprint. I cannot find a matching color does anyone know the gm paint code for a collector edition silver beige?
Old Oct 13, 2013 | 01:47 PM
rmm82's Avatar
rmm82
According to my trim tag, the paint code is 59. The link below provides Dupont and Ditzler numbers.
http://paintref.com/cgi-bin/colorcod...e&sname=Silver Beige
Old Oct 13, 2013 | 02:17 PM
bpassmore's Avatar
bpassmore
I have a CE. You will probably have to work with your paint supplier to get a good match. I have used of both of the companies paint, generally it takes a little fiddling with the tone and metal flake size. You may have to paint the whole panel. My front bumper is painted with the DuPont code. In some light it matches perfectly, then viewed from another angle ti goes lighter or darker. I think that is a flake size issue. Touch up is tough.
Old Oct 14, 2013 | 09:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Here are the old, original codes: http://www.corvettepaintcodes.com/
Old Oct 14, 2013 | 06:38 PM
DUB's Avatar
DUB
Tinting the color and spraying a test panel may be required. Just putting a paint stick in the can and pulling it out and checking the color that way DOES NOT WORK!!!
And the reason the color changes on the angle is due to an additive in the paint that can make the color do dark on the angle.
You need to have a good eye and check the angles ..and under different types of light...and if you do not shoot a test panel the EXACT SAME WAY as you plan to shoot the repair...do not expect the repair to turn out the same. I do so much tinting and color matching...I have found that PROCEDURE IS important...and this also goes as far as when you are shooting your test panel...and you have the mixed paint in your paint gun. You go and apply a coat on your test panel. Take you paint and empty this thinned/reduced basecoat back into your mixing cup with what you have already thinned/reduced. WHY do you ask????
WELL...if you shoot a coat on your test panel...then walk out of the booth for 10-15 minutes while it flashed off...because that is what you are going to do when you paint the car...the paint that is in your gun cup will allow the metallic's/pearls to settle in the bottom...and when you go and shoot another coat...the metallic's will throw off your color (lighten it) and now you do not have a PROPERLY MIXED COLOR to test.
The same will hold true when you go and paint the car. BECAUSE...normally when painting an entire car...a painter will empty hid/her gun back in the can...or have such a little bit left in the cup...he/she will pour it back into the "mix"...stir it and then fill up the cup again. And when painting an entire all-over...it is different than trying to match a color that is "touchy" to say the least.
DUB
To Paint code 82 collector edition
