Help with dash speaker screen repair.
The dash has been removed and I can dye the dash after the repair. I believe it's only a crack and no material is missing. The rest of the dash is in great shape.
Anyone had luck with such a repair?
The grills are a bit depressed at the moment due to the pressure I applied during cleaning but did reset into it's original position.
You mention the clogging the holes.... disregarding the holes, have you found anything that actually 'glues' the vinyl?
I'm thinking of a door panel, but I believe the vinyl is the same.... anything to glue that material? Not close a gap, just seal a split as shown in mmvlf's picture?
Regards,
Alan
Regards,
Alan
Wish me luck.
This is probably kind of a bubba fix, but this is what I did.
With mine, anyway, you could not see where I screwed it up if it was flat. The breaks closed themselves up and were hidden. So I used fiberglass strands underneath to hold them where they should be and you can not see it from the top.
I should mention that I sprayed dye on mine to go from red to black, so that may have helped. Also, two years later, I have never had it out baking in the sun, so I don't know how that will affect it. So far, though, it has held up to two years of being moved around in the shop with no problems.
Like I said, kind of bubba, but I could not shell out that much money to cover my own stupidity. Btw, after that I taped a small piece of cardboard over them so when I was upside down in the car working under the dash and I tried to pull my tired old body out, if I put my had there I would feel it and remember to find something else to grab onto.
Wish me luck.
I wonder if you could reinforce on the backside of the speaker holes a small piece of 'screen door' nylon that is spot glued on the areas of no holes to give some support. Once dried it should eliminate the tendency to 'depress' which likely caused the crack in the first place.
With that done could a wee bit of Crazy glue fill the cracks on top and a slight scuff with a Scotchbright pad remove any shiny signs of a freshly 'glued' repair?
Just trying to think of some solutions as I think a traditional vinyl repair would be too much for such fine work.
Once mesh is applied, that should stabilize that area so further cracking wouldn't occur; and the speaker sound shouldn't be impeded by the added mesh.
If the cracking on the surface is very noticible, a little polyester body filler laid into those small cracked areas (toothpick, flat-bladed X-acto knife, ???) should hide that cracking. And if some gets into those holes, a drill of the same size (or a bit smaller) twisted into those holes should draw out any excess putty.
Final step would be to recolor the dash cap (or only that area, if the dye match is really good). SEM "ColorCoat" liquid dye sprayed on would be the BEST choice, IMO. I'm not a fan of the aftermarket spray bombs that are called "interior dye".
