Temp gauge
Old Oct 11, 2013 | 09:37 PM
mrh747's Avatar
mrh747
Default Temp gauge
How can I test the temp gauge. I am concerned about letting the car run very long. Just seems it runs hot. Just repaired the carbureted, the heat gasket had portions burnt out. Just purchased, even thought matching numbers and original, bubba was there.
Help
Old Oct 11, 2013 | 10:17 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
Do you have an infrared thermometer you could use to check the temperature of the water outlet on the intake manifold? That is the easiest way I know of.
Old Oct 14, 2013 | 07:24 PM
mrh747's Avatar
mrh747
Thanks Dan, I do not, I thought I read something in the past about check/testing a temp gauge
Old Oct 14, 2013 | 09:52 PM
PeteZO6's Avatar
PeteZO6
Wilcox has a write up on this subject. The basic problem is replacement sending units don't give the correct resistance (ohms) for the gauge to read correctly. He has documented the different ohms reading for various temps for the gauge to be accurate.
But the easiest way to verify your temp gauge is as Dan 1495 suggested to buy an infrared thermometer. Harbor Freight has them pretty reasonable. When you know what temp the engine is actually running, you can then evaluate the accuracy of the tamp gauge.
Pete
Old Oct 14, 2013 | 10:08 PM
CanadaGrant's Avatar
CanadaGrant
Pete
Pete is right. The old gauges are inaccurate at best and I wouldn't trust one for a real temp. See if you can borrow an infrared to get a baseline on your gauge.
Old Oct 15, 2013 | 05:24 AM
QuRace's Avatar
QuRace
While I have gone down that path myself, three things keep me worried with this approach:
  1. The water outlet is NOT where the temp sensor sits; That's in the driver side cylinder head (at least on a '70 LS5). Readings will not be directly comparable...
  2. Measuring metallic surfaces with an IR gun is, I believe, difficult. Has to do with the emission coefficients of different materials; Better / more expensive IR guns have an adjustment for that.
  3. Also, IR guns measure the temperature of a certain area, the size of which depends on the distance between the gun and the object being measured. The laser dot used to target the gun is somewhat misleading in this respect.
Anyone care to comment, esp. on #2 & #3?
Old Oct 15, 2013 | 07:18 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
If you are that unsure of the in-dashtemp gauge, buy an inexpensive $25 aftermarket gauge that has the direct (copper tube with bulb) reading to compare with your in-dash gauge---they generally come with threaded adapters to fit your engine.
They're not rocket-science gauges, but will get within a few degrees of the actual temperature and are good for temporary testing....also test your engine thermostat opening-temp in a pot of heating water on the kitchen stove with a cooking thermometer....then you will have two reference points to get an idea of how accurate your in-dash gauge is without dropping a c-note on a decent IR gun (unless you're concerned about exhaust temps also--but that's another can of worms this rookie won't open)
Old Oct 15, 2013 | 09:22 AM
imariver's Avatar
imariver
IR guns can be very confusing, for the exact reasons stated above. There are a hundred different places to measure coolant temp's and no two will be the same.
Old Oct 15, 2013 | 11:55 AM
7T1vette's Avatar
7T1vette
More to the point:
If the gauge in your cluster reads at all, it is probably fine. If you have a 'calibration' problem, the issue is the sending unit. The sender provides the voltage signal which is merely "read" by the gauge in the cluster.
The sending unit is most likely your problem. To check the gauge function, remove the wire/connector from the sending unit. Now, turn the car's ignition switch to "RUN" position (engine OFF). With the wire removed from the sender, the gauge should read "0" [all the way to the left on the dial]. Now, touch (and hold) the sender wire to the engine block {ground}; the gauge should read all the way to the right on the dial.
If the gauge functions as expected, replace your sender unit.
PeteZO6's Avatar
PeteZO6
I'll tackle a couple. While the metal on the side of the head may be warmer than the metal of the t-stat housing, we're interested in COOLANT temperature; that's what all the in-car temp gauges measure. The end of the sending unit is surrounded by coolant. At either location, the coolant isn't sitting stagnant, it's moving at a good rate past the sensor. I have had my sensor (sending unit) in both locations and there was no difference in the gauge reading.
In the real world IR temp guns work very well. We're not looking at determining the correct temperature to the nearest one tenth degree, we're looking approximations and trends. Accuracy within a few degrees is sufficuient for this kind of work.
An IR gun is another tool to help in determining if there is a problem and where it might be.
Pete
Old Oct 15, 2013 | 02:35 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mrh747
...Just seems it runs hot...
Is your car running hot or just coming up to normal operating temperature? 190-220 is not over heating.
Old Oct 16, 2013 | 10:36 AM
mrh747's Avatar
mrh747
Default Temp gauge
Thanks for your responses. I ordered the IR gun. I did disconnect the wire from sending unit and touched it to ground. Nothing. I will keep trying.
Old Oct 16, 2013 | 12:39 PM
Peterbuilt's Avatar
Peterbuilt
Did you do the test with the key "ON"?
Old Oct 16, 2013 | 02:48 PM
7T1vette's Avatar
7T1vette
If removing the sender wire (with ignition in ON position) and then touching it to an electrically grounded spot registers no indication on the cluster gauge, then there are two possibilities:
1. The sender wire is damaged so that no signal can reach the gauge. Usually, this is at, or immediately behind, the connector that attaches to the sending unit...or somewhere in the engine compartment.
2. The gauge is defective. This would be unusual...unless there was significant voltage sent to that gauge by mistake.
The sender wire is the likely culprit.
Old Oct 16, 2013 | 03:04 PM
mrh747's Avatar
mrh747
Default Temp gauge
Yes I did have the ignition switch on.
I am in the process of replacing all wiring harnesses, like I said there is some bubba tracks. Not taking any chances. I am not fond of smoke.
So far, most items repaired or replaced was BS.
Old Oct 22, 2013 | 05:27 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
All of this can be found on the website Mrh747. There is more info there too...
Testing a 68-76 Temperature Gauge -or- What your non working gauge can tell you!
Old Oct 22, 2013 | 07:32 PM
mrh747's Avatar
mrh747
Default Temp Gauge
Thanks Wilcox, I do visit you site and support your organization
To Temp gauge
