Front End noise
Old Oct 12, 2013 | 11:07 AM
Nomad09's Avatar
Nomad09
Default Front End noise
I have an issue with my 77, as you are braking, the front end makes a loud noise just before full stop. I had a seal go on the right front caliper, I didn't think the pads got fluid on them, but wondering if that could be the problem. Car is going away for the winter so will order o-ring calipers in the spring to stop the leak. Could this be from contaminated pads? Or could something else be the culprit?
Old Oct 12, 2013 | 11:13 AM
MelWff's Avatar
MelWff
a loud noise is more likey suspension related. Look for worn out bushings, missing alignment shims, etc.
Old Oct 12, 2013 | 12:59 PM
wombvette's Avatar
wombvette
LOUD noise? A train makes a loud noise, a nuclear bomb makes loud noise. How in the heck can anyone even attempt an answer to that question.
Old Oct 15, 2013 | 09:13 AM
Nomad09's Avatar
Nomad09
Well I realize the question is rather vague, but I can't really describe it, it not a clunk, creak or rattle. If I could figure out how to make a clip of the noise I would and then figure out if it can be attached here.
Old Oct 15, 2013 | 09:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Take the car to the Chevy garage or a shop; let them listen to your noise.
Old Oct 15, 2013 | 10:34 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
A loud groaning noise just before stopping is probably brake fluid contamination on the pads, especially with harder compound pads. Clean the rotors with spray brake cleaner and replace the pads.
To Front End noise
