Sealant needed on pipe plugs?
Old Oct 14, 2013 | 01:08 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default Sealant needed on pipe plugs?
Hello,
I'm replacing the passenger side manifold on my '68 BB and am installing 4 new pipe plugs. Both outer ears fell off the orig. manifold when removed.
Do these plugs need some thread sealant or install dry?
They all go in about the same depth with about 3-4 rows of thread exposed when tight. That sound about right?
Thanks,
Marshal
Old Oct 14, 2013 | 05:38 AM
7T1vette's Avatar
7T1vette
You can use #2 Permatex or pipe thread sealant. You do NOT want to use any silicone product, except for black RTV (which can handle coolants and petroleum products).
Also, don't overtorque lubricated pipe plugs. With sealant, you don't need to put much torque on them; and you can split the manifold if you tighten too much.
Old Oct 14, 2013 | 10:40 AM
TimAT's Avatar
TimAT
The plugs in the exhaust manifold? Are you using brass or steel plugs? The heat will cook just about anything you put on them.
Old Oct 14, 2013 | 12:48 PM
7T1vette's Avatar
7T1vette
Oops! OP didn't state "exhaust" manifolds. No, no sealant on them.
Old Oct 14, 2013 | 01:10 PM
mds3013's Avatar
mds3013
If these are for the AIR pump holes then you want to use this type of plug. Line threads not tapered pipe threads. No sealant required. mike...
Old Oct 14, 2013 | 03:00 PM
scottyp99's Avatar
scottyp99
Originally Posted by marshal135
Hello,
Thanks,
Marshal
So.....the OP is replacing the passenger side intake manifold? Is he also replacing the driver's side intake manifold?
I figured he was talking about the exhaust manifold, too. I was wondering what he was talking about with the pipe plugs. I'm still wondering what he means by the ears of the manifold falling off. Anyway, a smear of High Tack or Ultra Gray, justabout anything that won't be degraded by coolant, wouldn't hurt anything.
Scott
Old Oct 14, 2013 | 03:14 PM
TimAT's Avatar
TimAT
I took the OP to mean exhaust manifold. Given the frequency the factory cast manifolds have problems. I've pulled factory BB manifolds that were perfect, gently laid them aside, and they were cracked when I went to re-install. Same with SB manifolds. How many I've heated with a rosebud to get them to spread enough to get all the bolts started.
Old Oct 14, 2013 | 03:18 PM
mds3013's Avatar
mds3013
Put them outside in the Texas summer sun and they will grow. mike...
Old Oct 15, 2013 | 10:53 AM
marshal135's Avatar
marshal135
Default Exhaust Manifold
Ok everyone thanks for the replies.
My evap box had a hole in since some body before me bumped the exhaust manifold thru it.
To take out box for replacement the pass side exhaust manifold had to come off no way around it on a BB
Upon removing both the bolts at the far ends of the manifold the tabs for the bolts just fell off. They had been broken a while as the orange paint showed exhaust flashing or soot from an obvious leak.
I obtained an orig. manifold and 4 new plugs.
Hence my question regarding sealer or not?
The plugs are not brass but thread in nicely.
I will not go crazy tightening these things.
I bought 1/4 by 18 nps square headed plugs.
As for the drivers side I haven't found it cracked so I'm leaving that side alone for now.
I'll install dry.
Thanks everyone for the replies.
Marshal
To Sealant needed on pipe plugs?
