Tie rod ends
Old Oct 13, 2013 | 10:34 AM
archer417's Avatar
archer417
Default Tie rod ends
This may be a dumb question but I'm trying to relearn all the stuff I've forgotten over the last 30yrs.
I'm slowly re doing the suspension and plan on replacing the ends anyway but my question is this: The joint should be tighter than this correct? I'm thinking that I shouldn't be able to move them with my hand.
Old Oct 13, 2013 | 11:44 AM
7T1vette's Avatar
7T1vette
You should be able to 'twist' links that have ball joints on both ends; but there should be no free-play when you lift or pull on them.
Old Oct 22, 2013 | 03:14 PM
archer417's Avatar
archer417
If I was trying to lift or pull on them, should they be checked with the wheels on or off the ground?
Old Oct 22, 2013 | 04:06 PM
RDCRIS's Avatar
RDCRIS
On the ground.
Old Oct 22, 2013 | 06:22 PM
qwank's Avatar
qwank
off the ground. hands on 9 and 3 and wiggle back and forth. should be no play in the tie rod ends.
Old Oct 22, 2013 | 06:49 PM
RDCRIS's Avatar
RDCRIS
I like to check them on the ground and have a helper turn the steering wheel back and forth to check for wear. That way the rods don't have a load on them when the wheels are hanging down.
To Tie rod ends
