Neutral safety switch
Old Oct 22, 2013 | 12:48 PM
tmacd's Avatar
tmacd
Default Neutral safety switch
Is there a way to test the neutral safety switch without just getting a new one
Old Oct 22, 2013 | 07:18 PM
DUB's Avatar
DUB
YES.
The large purple wires that are attached to it will be a closed circuit when the switch is in park or neutral. In any other gear..these wires should be open. The pink and light green wires are for your reverse lights. An ohm meter or continuity tester will aid in checking the switch. It does not need to be disconnected to test.
DUB
Old Oct 22, 2013 | 07:31 PM
tmacd's Avatar
tmacd
Originally Posted by DUB
YES.
DUB
Thanks DUB I will give that a try
To Neutral safety switch
