Power brake conversion.
Old Oct 13, 2013 | 08:17 PM
jd101's Avatar
jd101
1st Gear
Default Power brake conversion.
I have read numerous threads on power brake conversions. I currently have a 70 454 with manual brakes and steering. I am converting both to power. I am going to remove the pedal support to modify it to accept the booster studs. Am I correct the easiest way is to remove the column first. If so, does the cluster have to be removed to fully remove the support? Thanks.
Old Oct 14, 2013 | 09:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My guess is you will want to remove the driver's side dash just to have room to work.
