1981 C3 rotor?
Old Oct 20, 2013 | 07:25 PM
nspctr01's Avatar
nspctr01
Default 1981 C3 rotor?
Is there a difference between the front and rear rotors on these cars? I took them all off to have them turned and when I got them back the shop had cleaned them up a bit and scrubbed off the Identifiers I put on them.
Old Oct 20, 2013 | 07:40 PM
rbowman's Avatar
rbowman
The rear should have the access hole for the park brake.
Ron
Old Oct 20, 2013 | 07:42 PM
garygnu's Avatar
garygnu
they should be interchangeable ,is that a word ?Ron is correct ,I love all the things I learn on this forum .next time your rotors get glazed ,you can use a 3M wheel and a drill to scuff them up .get new brake pads if your current pads are less then 1/4" .
Old Oct 20, 2013 | 08:12 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
The rear ones have a brake drum built into the hat for the parking brakes.
Old Oct 20, 2013 | 08:16 PM
'75's Avatar
'75
I think the offset is slightly different, but the rear will have the access holes for the park brake adjustment,
Old Oct 20, 2013 | 08:22 PM
nspctr01's Avatar
nspctr01
OK, I have them backwards then. Good thing I asked before I installed all 4.
Old Oct 20, 2013 | 09:25 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
See the extra holes.. this is a rear.
Old Oct 21, 2013 | 09:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by nspctr01
Is there a difference between the front and rear rotors on these cars?...
Yes.
...I took them all off to have them turned and when I got them back the shop had cleaned them up a bit and scrubbed off the Identifiers I put on them...
C3 rotors should be turned with the hubs as a unit. That's why they are riveted at the factory. You will need to check run out on all four corners.
Old Oct 21, 2013 | 10:38 AM
joewill's Avatar
joewill
I learned the hard way a couple of years ago too. the shop sent me a front rotor for the rear.. the offset is a tiny bit different and I got some grinding where the rotor kissed the caliper. A tiny bit of grinding on the caliper with a dremmel solved the issue.
so yes, look for the extra holes for your parking brake adjustment slot in the rears..
I prefer to adjust my parking brake to "feel" vs adjusting with the rotor on since it is so hard to back it off with the adjuster in order to get the rotor off later.
Old Oct 21, 2013 | 10:47 AM
Mike Ward's Avatar
Mike Ward
+1
Not to mention that 99.9% of Corvette rotors NEVER require turning in the first place.
Old Oct 22, 2013 | 01:02 PM
nspctr01's Avatar
nspctr01
Got it!!!
SO, hubs and rotors were separated when I got car. I've read where they do not require fastening to each other again and then there was the article that said to use a short bolt and reattach them to each other.
What is best? what bolts or fastening method do you use if so.
Thx
Old Oct 22, 2013 | 01:42 PM
rbowman's Avatar
rbowman
Since they have already been seperated, I would use the wheel and lug nuts to hold them in place. I would also check rotor run out since excessive run out will allow air into the system.
Ron
Old Oct 22, 2013 | 02:29 PM
Mike Ward's Avatar
Mike Ward
Thx
None- it's not required or of benefit nor will it cure any runout problems.
To 1981 C3 rotor?
