Quadrajet
Old Oct 23, 2013 | 09:46 AM
DM76's Avatar
DM76
Default Quadrajet
OK, I have rebuilt my carb again and still runs rich. It is a 76 vette carb # 17056206. It has 76 jets in it and I'm thinking its to much. And now it looks like the power piston is stuck. I know I need to take it apart and replace the plastic retainer but does anyone know the right jet size before I take it back apart? And if I change the jets to smaller ones should I change the 44 26 tip metering rods?
Old Oct 23, 2013 | 10:24 AM
MelWff's Avatar
MelWff
77 is the correct number download this document and scroll down
http://www.corvettefaq.com/c3/QJetTuningPaper.doc
Old Oct 23, 2013 | 01:10 PM
lars's Avatar
lars
If you're running rich, you have problems not related to the jets. You need the 77 jets in that carb for it to run right. The rods should be 48's (48K). There is no need to replace the plastic power piston retainer - it has no effect on performance or operation, unless it is broken in a way which jams the power piston.
Lars
Old Oct 23, 2013 | 10:16 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
How do you know she's rich? If she smells rich at idle, your float could be maladjusted.
Old Oct 24, 2013 | 12:21 PM
Eljay's Avatar
Eljay
Lars, I gave the paper a quick read and that is some great stuff! I have been thinking that I would really like to know about tuning Q-jets and tihis will be the ticket, thanks for taking the time to put this together.
Old Oct 24, 2013 | 01:18 PM
lars's Avatar
lars
I don't show that I have sent you a paper... Don't use any of my papers you find posted on the Internet, including the ones posted here on this Forum: Those papers are outdated and obsolete - don't use them. For current, valid papers, e-mail me directly a request for the papers you want.
Lars
V8fastCars@msn.com
Old Oct 24, 2013 | 07:31 PM
DM76's Avatar
DM76
Thanks I appreciate the help. Found a carb shop close by and they said the same thing. The 77 jets and 48k rods are right. But I have 76 jets in carb. Took the air horn back off and one of the metering rod arms was bent down. Bent it back in place and polished the power valve assembly to a mirror finish, recommended by shop to prevent sticking. Put everything back together and when for test ride. What a deference. I also tapped the air horn so I can adjust the auxiliary for power valve. Can't final tune car yet until MSD distributor comes in hopefully tomorrow. Old one just plain worn out. Thanks again.
Old Oct 24, 2013 | 09:55 PM
gcusmano74's Avatar
gcusmano74
Yes. When the factory stuff is set up correctly, these cars will run and drive well. You don't have to drop a dumptruck load of cash into them .
You can spend a bunch of money on trick parts, and make the car DIFFERENT. But it's not so easy to make the car BETTER.
Old Oct 25, 2013 | 10:21 AM
lars's Avatar
lars
I wouldn't worry about a 1-size jet discrepancy. Your 44K rods are going to run you a little rich at cruise, but you can offset that by running the APT setting a little deeper. If I were rebuilding the carb for you, I'd put the "correct" parts in it, but for all practical purposes, your carb is going to run fine as jetted, providing you have all other parameters setup up correctly.
Lars
Old Oct 25, 2013 | 09:12 PM
DM76's Avatar
DM76
I did run the APT deeper. I'm at 2 turns from bottom now. Put in MSD distributer tonight and hope to start it up and finish tuning tomorrow. I'm keeping my fingers crossed. I was getting to much advance at idle before.
Old Oct 27, 2013 | 09:04 AM
Eljay's Avatar
Eljay
Hey Lars, I was looking at the link that Melwff posted, if that is not correct info I will email you for the correct info. I see you also have timing info. I want my 70 454 to run correctly. Thanks
Old Oct 27, 2013 | 09:59 AM
scottyp99's Avatar
scottyp99
Could you go into a little more detail about "getting to much advance at idle"? How much advance were you getting? It's kind of unusual to see a distributor that is "worn out", they only spin at half the engine speed.
Scott
Old Oct 27, 2013 | 11:05 AM
lars's Avatar
lars
None of the sites posting my papers keep the papers up to date, resulting in obsolete and outdated info being posted. Don't use any of my papers posted by others on the 'Net. Current, valid papers are available by e-mailing me a request for the papers. You can also obtain a complete listing of all tech papers I have available by dropping me an email request.
Lars
V8FastCars@msn.com
To Quadrajet
