starter recommendations
Old Oct 26, 2013 | 01:46 PM
7t9l82's Avatar
7t9l82
i wonder if i could chuck my existing bolt in the lathe and knurl them?
Old Oct 26, 2013 | 02:15 PM
qwank's Avatar
qwank
the stock bolts are way too long, you'd have to cut them down.
Old Oct 26, 2013 | 02:21 PM
7t9l82's Avatar
7t9l82
so much for that idea.
Old Oct 27, 2013 | 12:59 AM
Solid LT1's Avatar
Solid LT1
NO! the bolts are case hardened in their process of manufacture, the knurling is done before the hardening process. I don't know of a knurling tool that will displace case hardened material.
Old Oct 27, 2013 | 01:28 AM
7t9l82's Avatar
7t9l82
well, another idea shot down. i think i will look for a gear reduction starter that comes with the bolts.
Old Oct 27, 2013 | 09:44 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
I installed a DEI mini torque starter about 1 year ago.
So far flawless operation.
Restarted after idling in a 4th of July parade for over an hour.
Now if that's not heat I don't know what to tell you.
I think it was around $59.00 probablycheaper through amazon now.
It's a 168 tooth for a 427. No shims needed.
Droped the old one out, put in the new one.
Just make a mental note where the wires go before removing.
Should take you anywhere.
Marshal
Old Oct 30, 2013 | 10:45 PM
7t9l82's Avatar
7t9l82
picked up a hitachi with shims and bolts, anybody use one? do you normally have to use the shims?
