starter recommendations
Old Oct 25, 2013 | 02:00 PM
7t9l82's Avatar
7t9l82
Default starter recommendations
im looking for a new starter and want some input. i would like something lighter and more compact. i was going to do a search but sometimes new stuff comes along, thanks
Old Oct 25, 2013 | 02:54 PM
qwank's Avatar
qwank
I'm using a stock starter from a '98 Tahoe
Old Oct 25, 2013 | 03:04 PM
MelWff's Avatar
MelWff
You have about 90 choices which can be narrowed down by filtering
http://www.summitracing.com/search/y...eyword=starter
Old Oct 25, 2013 | 06:04 PM
Ironcross's Avatar
Ironcross
Smart choice, and relatively inexpensive compared to the modified high priced import 4 cylinder starters pushed on the internet by mail order houses.....
available at every auto parts store too........
Old Oct 25, 2013 | 06:06 PM
speedreed8's Avatar
speedreed8
same here, lightweight, readily available, gear reduction,,, probably will need some shorter bolts. works great.
Old Oct 25, 2013 | 06:12 PM
7t9l82's Avatar
7t9l82
i take it that the tahoe starter would use the bolts for that year tahoe?
Old Oct 25, 2013 | 08:00 PM
zwede's Avatar
zwede
No, by 1998 the bolts were metric.
Old Oct 25, 2013 | 09:27 PM
vettezobsezzed's Avatar
vettezobsezzed
Default Starter
I haven't used it yet, but I just bought one on eBay, skipwhiteperformance high York mini started. 3hp, 68$. + 45$ shipping to Canada. Took 3 days, just picked it up
Old Oct 25, 2013 | 10:40 PM
qwank's Avatar
qwank
I Forget which bolts I used, but they were in stock at the dealer. I had to grind down the starter housing a little to fit in the clutch inspection cover.
Old Oct 25, 2013 | 11:18 PM
garygnu's Avatar
garygnu
for pre 1983 you would use standard bolts thread .buy a grade 8 3/8 bolt 1" longer then the starter housing mount .that will give you room for starter shims .
Old Oct 26, 2013 | 01:07 AM
Solid LT1's Avatar
Solid LT1
Late model GM metric starters use 10mm bolts about same as 3/8 SAE so they interchange. You need to know your flywheel ring gear tooth count, 10.5" clutch is 153 tooth, 11" clutch/TH400 168 teeth. One of my favorites is a 1988 and later C4 gear reduction DENSO starter, OEM GM but, may cost some money and only for a 10.5" 153 tooth flywheel. CVR makes a good starter, Hitachi also watch out for the Chinese junk out there and make sure it is a full roller bearing starter, some use a bushing on the drive end, and will slowly wear in use, causing flywheel ring gear destruction. Budget around $175-200 for a quality part.
Stock GM starter mounting bolts have a knurl on them to prevent misalignment of the starter, use a standard non-knurled bolt and you risk mis-alignment and flywheel ring gear damage.
Old Oct 26, 2013 | 08:06 AM
zwede's Avatar
zwede
I disagree that 3/8" and 10 mm bolts interchange. Using 3/8" bolts will leave 0.5 mm of slop. That's enough to misalign the starter.
GMPP makes special bolts with a 10 mm shoulder and 3/8 threads. Or you can do what I did: Insert thin wall brass tubing to remove the slop. Found it at the HW store.
Old Oct 26, 2013 | 10:38 AM
ezobens's Avatar
ezobens
What flywheel does the Tahoe starter work with (153 or 168)?
The 153 starter has the straight across bolt pattern and the 168 starter is staggered.
Thanks!
Old Oct 26, 2013 | 10:42 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I got one of those Summit mini-starters when they 1st came out. One of the best mods I ever made.
Old Oct 26, 2013 | 10:59 AM
zwede's Avatar
zwede
Dunno about the Tahoe, but a 1995 K2500 truck w/ 7.4 liter V8 has the staggered pattern. That's what I use.
Old Oct 26, 2013 | 11:13 AM
ezobens's Avatar
ezobens
I'm running the 153 tooth flywheel so the staggered starter is out for me.
Old Oct 26, 2013 | 12:14 PM
Kid Vette's Avatar
Kid Vette
GM makes starter bolts to adapt these mini-starters to the Gen I small blocks. These are the bolts for the 153 tooth flywheel starters.
The short one is PN 14037733 and the long one is 12338064. They have 10mm shanks with 3/8" threads.
To starter recommendations
Old Oct 26, 2013 | 12:41 PM
Solid LT1's Avatar
Solid LT1
WOW! maybe those will work to properly locate a 10mm hole but, WTF do I know
Old Oct 26, 2013 | 12:50 PM
qwank's Avatar
qwank
I'm pretty sure those are the bolts I used
Old Oct 26, 2013 | 01:14 PM
v2racing's Avatar
v2racing
I bought a cheap Hitachi style mini starter off of eBay about 7 years ago for my 64 SS. It has performed flawlessly. The gear drive starters sound different than the stock starter. It sounds more like a Chrysler product starting. If it failed today, I more than got my moneys worth. I think I paid $59 for it.
I bought another cheap starter off eBay for my Vette. It is the late GM mini starter style. I'll see how that one goes.
