82 Corvette Replacement sending units
Also..DO NOT ASSUME that the wires are connected correctly in the connector that clips into your factory body wiring.
This is easy to check. Disconnect the connector to your new pump and with a helper...have them turn your key on and see if you get 12 volts to the power wire going to the pump...and ground on the other...by using a volt meter...NOT a test light.
DUB
DUB
Idk if our vettes have it, I have not had to do my 82 yet.
One thing to keep in mind. That if you use a voltmeter and are checking a circuit that is NOT working. And when you go and check the circuit with the voltmeter and it shows that 12+ volts is present as it should be. That does not ALWAYS mean that it will work.
The reason being: AMPS.
You can use a car speaker wire and go from your battery to the starter. It will carry 12+volts. It will OHM out correctly,,,and show continuity. BUT...when you go to crank your car...the gauge of the wire (being so small) CAN NOT handle the AMP LOAD that the starter needs to operate...thus melting down the small speaker wire. So..this is why the wire/cable to your starter is so large. So it can carry and handle the severe amp load when the starter is being used. SO..using this know fact. Your wire in your new sending unit may have 20 strands to make up that gauge of wire(for example). Which if they all are not broken..can carry the load that the fuel pump will require to operate. BUT...if 18 out of the 20 are broken...those 2 strands can not carry the load and will fail...BUT...when you test for volts, ohms and continuity...it will show to be "good"...because it is good... because you still have wires going form "A" to "B".
SO...IF EVER you have a wire that is in question of its gauge integrity (broken stands within). I remove/disconnect BOTH ends of the wire in "question". I then use a high/low beam headlight and wire it so BOTH high and low beam will burn when energized to ONE END of the wire in question. This wire in question, on the OTHER END will be attached to a 12 volt power source. IF the headlight will burn...the same as if you hooked up the headlight to your battery directly...then the wire is good. IF it does not work or is dim...then the wire is bad...this also is ASSUMING that you connected it correctly and secure and the ground is also connected well.
This procedure has saved me more times than I can count over the years.
DUB
Yes I believe it has to do with the 12 volts getting to your connector for your new fuel pump in the new unit. You can have 12 volts at the end of the factory plug in the body wiring...but if the current can not make it to your connector at your fuel pump...it will not work. And this also applies to the GROUND circuit.
DUB
