Rear Spring Positioning
Old Oct 27, 2013 | 01:04 AM
wayneyada's Avatar
wayneyada
Default Rear Spring Positioning
I am new to Corvettes and this forum, so please bear with me <g>.
I just replaced the rear spring mount bolts, bushings, washers, and nuts on my buddy's 74. I'm concerned about the front-to-rear lineup of the mounting holes in the spring ends and the wheel assembly (see pictures). It appears to be a good 1" difference with the spring being further back than wheel assembly. I couldn't see any way to move the spring assembly forward. Maybe it will get better when I put the wheels back on it and drop them to the ground???
Any thoughts/direction would be most helpful!!
Thanks in advance for your help!
Wayne
Old Oct 27, 2013 | 01:42 AM
Mike Ward's Avatar
Mike Ward
Yes it will.
Old Oct 27, 2013 | 08:15 AM
Alan 71's Avatar
Alan 71
Hi w,
WELCOME!!!
First post, and a question that MANY people have wondered about.
Mike's right...the bolt alignment will improve.
Remember the rear of the t-arm moves in an 'arc', so the mounting point for the spring bolt moves forward as the t-arm drops far below or goes high above the position it's at when the car is just sitting on the ground.
Hope to see more of you and your car here.
Good Luck!
Regards,
Alan
Old Oct 27, 2013 | 08:56 AM
redrdstr72's Avatar
redrdstr72
Hi and welcome, Wayne. As Mike and Alan have already offered, the alignment due to arcing should improve with weight on the wheels. At least it did on mine. I was very worried and even had to remove one shock to get enough arc when R & Ring my rear spring.
I did notice, however, in your photos how you didn't peen the new cups over once installed through the trailing arm (upper cup) and through the spring itself. The factory peened them both, thereby "locking" them into position.
Does the group here think this will be alright over time, or is there a worry that the cups could come out of position due to not being peened over?
Old Oct 27, 2013 | 09:02 AM
Alan 71's Avatar
Alan 71
Hi rr,
Nice eye!
Raises the question... where the cups peened because of the reason you suggest, or because they came to the line as part of an assembly so had to be peened to hold them in place until the bolt and bushings were installed?
Don't know!
Regards,
Alan
Old Oct 27, 2013 | 10:30 AM
Mike Ward's Avatar
Mike Ward
Probably not one person in a hundred has taken the time to peen them over, never heard of a problem and can't imagine how one could occur.
Old Oct 27, 2013 | 11:50 AM
redrdstr72's Avatar
redrdstr72
Uh oh. Guess I'm one of THOSE people.
I replaced my spring a few years back, and when I did, I peened new cups on the new spring. Being able to do it on a bench made it much simpler than I imagine it would be for the trailing arm. I did not have the TA's out, so it wasn't necessary for me to worry about those cups at the time.
I did mine with a large ball peen hammer, struck with a 5 pound sledge, ball side first then the flat side, thereby enabling the cuff to find its way to form without splitting. I was actually proud of myself on that one. To accomplish this in the trailing arm, I suppose a drawing/clamping - type fixture would be required. I think one of those has been devised, as I've read about it on the NCRS TDB.
I do know that the judges take demerits when an "un-finished" cup is observed. I did mine for this reason as well as the old "that's the way it came, so that's how it oughta be" syndrome.
Good to hear that there may be little risk of the cup coming out of position, especially for the 99%ers ()...
Old Oct 27, 2013 | 04:10 PM
wayneyada's Avatar
wayneyada
Thanks to all for the quick responses and confirmation that there's not something "drastically wrong" <g>. This car was purchased "in boxes", and we're in the process of putting the car back together using those boxed parts plus a few new purchases. As a result, I'm sure I will be back to the forum a lot! Thanks again.
To Rear Spring Positioning
