Headlite override switch- how does it work?
Old Jul 6, 2002 | 01:29 AM
Stevo81's Avatar
Stevo81
Default Headlite override switch- how does it work?
The little vacuum switch that sits under the dash btwn drivers knees...mine doesn't do anything, totally stationary. Should it push, pull, rotate...?thanx :seeya
Old Jul 6, 2002 | 06:05 AM
Shark Racer's Avatar
Shark Racer
Default Re: Headlite override switch- how does it work? (Stevo)
You should be able to pull down on it.
When it's down, it will force the headlights up, even if they are off.
-Steve
Old Jul 7, 2002 | 01:15 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default Re: Headlite override switch- how does it work? (Pacin'California)
You pull it (down), it's not as easy to pull as the headlight switch on the dash, but don't pull too hard. I've already broken a headlight switch pulling too hard :cry
Does your switch move at all?
[Modified by Buffalo Dude, 9:17 PM 7/6/2002]
Old Jul 7, 2002 | 12:45 PM
PRNDL's Avatar
PRNDL
Default Re: Headlite override switch- how does it work? (Buffalo Dude)
If it is stuck, you might try reaching up and holding the upper part of it with your left hand while pulling down on the end of it with your right hand. A sharp tug with right hand only could yank the whole switch out from under the dash, or break it in 2 pieces.. :( MJ
Old Jul 7, 2002 | 02:22 PM
rainman69's Avatar
rainman69
(Just in case...)
There are four switches under my dash ('69). From left to right they are: trip odometer reset (by itself), headlight override, wiper electrical override, wiper door override.
Pull down either of the vacuum switches, and the respective part opens. Turn the "****" and the wipers freeze wherever they are in travel.
Old Jul 8, 2002 | 01:31 AM
Stevo81's Avatar
Stevo81
Oh, ya...it was real Stuck...but came loose and works ok now. I didn't check the price on the little bugger, just said a prayer and pulled hard...thanx
To Headlite override switch- how does it work?
