Body Damage
Old Oct 28, 2013 | 08:31 AM
Peter O'Connor's Avatar
Peter O'Connor
Default Body Damage
I have a 69 427 tri-power. I crashed the car a couple of days ago. The damage is mainly forward of the radiator. The fiberglass on the front of the car is badly damaged in that the wings/inner skirts on both sides of the car are split and/or torn .
In terms of the future value of the car is it better to get a complete new front end or to try to have the original wings repaired? I live abroad and there isn't much experience of repairing fiberglass let alone corvette's.
I was looking at a Pre-Assembled Press Molded Front End and can't figure out how it is attached to the body ?
All help greatly appreciated
Peter
Old Oct 28, 2013 | 08:49 AM
zwede's Avatar
zwede
For future value it sounds the damage is bad enough that you should replace with new press molded panels.
The fenders are bonded to the firewall area using a bonding adhesive. The front is mainly held by 6 bolts that go into the radiator support.
Old Oct 28, 2013 | 09:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Peter O'Connor
...I was looking at a Pre-Assembled Press Molded Front End and can't figure out how it is attached to the body? All help greatly appreciated...
It bonds to the firewall at several different places. Do you have the 69 assembly instruction manual (AIM). The AIM shows the bonding points.
Reasonably good references here:
http://www.glas-ra.com/rearhl1968thru1982.html
Old Oct 28, 2013 | 10:23 AM
Sorry to hear about the damage to your car. Don't know a lot about body work, but hope you get the car repaired soon.
Old Oct 28, 2013 | 12:54 PM
rponfick's Avatar
rponfick
Good information posted. For a valuable car like your's, you should go with the press molded stuff. It is more expensive than the other stuff, but will help retain your value.
I had the same issue a number of years ago on my '69, L71. Ordered front clip from Corvette Image up in Oregon. Not sure how many manufacturers there are remaining of press molded replacement parts.
Just don't use the fast set up adhesive. Good for pro's, but not so good for do-it-yourselfers.
Ralph
Old Oct 28, 2013 | 01:27 PM
jnealg's Avatar
jnealg
sounds like we both had a bad weekend. I had a tangle with a tree that jumped out behind me when I backed up. going to the shop tonight for an estimate.
just kills ya dont it. I cant stand to even look at it and no one to blame but my self.
good luck and let us know how it goes!
Old Oct 28, 2013 | 11:12 PM
Solid LT1's Avatar
Solid LT1
If you cracked up the front end that badly, I would guess you have a bent frame too, I think you need to find someone competant to look over your Vette or post some photos. Where do you live? there are many members on this forum from other countries, maybe they can give a pointer on who to have asses the damage. Sorry to hear about the accident.
Old Nov 1, 2013 | 05:30 AM
Peter O'Connor
Thank you all very much for your replies and commiserations. Mine is a 69 l 71 as well Ralf . I hadn't mentioned it but a women reversed into my car having missed a turn. Never saw me .
I live in Dublin Ireland .
Good luck jnealg with your quote .At least you are fortunate enough to have experts all around you.
I will try to put up a photo .Its just I am not sure how to do it.
Thanks Again
Peter
Old Nov 1, 2013 | 05:35 AM
Peter O'Connor
Default Body Damage
Two photo's of the damage might help.
Peter
Old Nov 1, 2013 | 09:22 AM
wombvette's Avatar
wombvette
I would put a left fender and surround on it, probably innerfender too. It got hit in the most vulnerable spot.
Pay my way to Ireland next summer and I will fix it for you.
Old Nov 1, 2013 | 09:30 AM
zwede's Avatar
zwede
I agree. The fender has a crease over the wheel, that's the biggest reason for replacement, IMO. Very difficult to repair.
So new driver's side fender and top surround. Did the same thing on my '71. Got the panels from Corvette Image. They use original GM molds and the panels are press molded. The surround & fender were about $1,500. The header bar was already bonded on which was nice. Remember to save the headlight opening reinforcement strips (4 pieces). They are not included with the new surround. You also want a new bonding strip.
Good news is it can all be repaired to where it is as good as new!
Old Nov 5, 2013 | 12:55 PM
Peter O'Connor
Thank you all very much for your help.
I have taken a note of all the important info.
Regards
Peter O'Connor
To Body Damage
