1972 LS5 fuse panel question
Old Nov 7, 2013 | 07:58 PM
GregS_72's Avatar
GregS_72
From: St Louis MO http://1972corvetterestomod.blogspot.com/
Default 1972 LS5 fuse panel question
My recently acquired '72 LS5's turn signals, reverse lights, courtesy light don't work and in the process of running it down. Looking at the fuses and my fuse panel looks like below and found the pdf image below of the fuse panel from an earlier thread. Am I missing the "circuit breaker" and "fisher body feed"... what symptoms would those missing cause?
thanks!
Old Nov 8, 2013 | 10:35 AM
MelWff's Avatar
MelWff
It looks to me that you have something plugged into IGN, that is I believe normally empty. The plug that is in there could be what should be plugged in higher up in the BAT position. You dont have an AIM or the Chasis Service Manual?
