Engine Temp
Old Nov 9, 2013 | 12:53 PM
noonie's Avatar
noonie
If you want heat replace the tstat with a 195°
From your readings, it sounds like yours isn't working properly anyway.
Back in the early 60s most vehicles came with a 170° tstat and it was recommended and a common practice ritual to change to a 195° tstat before winter at the same time you put on your snow tires.
If you didn't you barely could defrost the windshield.
Big trucks have and still do come with temp controlled grill shutters to control radiator air flow. Some old ones had snap on zippered canvas on the grill.
Old Nov 9, 2013 | 04:09 PM
7t9l82's Avatar
7t9l82
I've seen oil temp over 200 with coolant temp of 160. the 2 temperatures are not parallel .
Old Nov 9, 2013 | 05:00 PM
Paul L's Avatar
Paul L
That brings back memories! That is exactly what was done. At -20*F that 195 sure helped out.
But these posters just need 180*F t-stats. Even with plain water (not recommended) that will bring the operating temp up to at least 180.
Old Nov 12, 2013 | 03:39 PM
rafalc's Avatar
rafalc
Any brand thermostats better than the others?
Old Nov 13, 2013 | 07:57 PM
rafalc's Avatar
rafalc
Originally Posted by paul 74
Thermostat is not installed or if it is, it is stuck open. Put a new one in.
Hi
In my case it wasn't the thermostat. I had the car running for a while, used an IR gun on the upper hose and the engine surface around the thermostat. Upper hose showed 170, engine around the stat showed 200, gauge was still at around 130.
Cleaned the sending unit, plugged the wire back in, now the needle wouldnt go much past 100.
With car idling, wire removed, needle drops all the way down, I still have to see what happens when I ground it, hopefully it goes all the way UP which I think will confirm its the sending unit?
