My BB update Engine pics :)
Old Jul 7, 2002 | 04:21 PM
Corey_68's Avatar
Corey_68
Default My BB update Engine pics :)
I just put the heads on and need to put on the pan as well as painting the heads.
Here's a rundown on the motor:
Gen V 454H.O. 4 bolt main +.060
Speed pro forged piston w/ 210 dome (10:1)
Stock forged rods 7/16 rod bolts
stock forged crank
mild port and polished Gm iron heads
2.19/1.90 valves
119cc / 325cfm
Comp cam 294 solid w/ comp cam springs
double roller timing chain
G.M H.O intake dual plane (may change do to clearance)
850 Speed demon w/ mech secondaries
Vertex Magneto distributor :eek:
headers Hooker chrome sidemounts
Our '67 GTO 4spd conv in the forground
You can see my C4 in the foreground, I'm taking all the LPE goodies off, you can see the Super Ram on the garage floor.
Here is a pic of our '00 Northstar Cadillac STS motor, we stripped all the paint off before get get it chromed. It has a LS6 intake and a larger throttlebody, all forged internals, can you say NITROUS :eek:. This motor is going in our '37 Buick Sedan backed by a 700R4, Z28 rear, mustang II front (4 wheel disk)
:cheers:
[Modified by Corey 68, 4:46 PM 7/7/2002]
Old Jul 7, 2002 | 04:36 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: My BB update Engine pics :) (Corey 68)
Looks good. You're a couple steps ahead of me. Today I chased all the threads and scrub a-dub-dubbed. Then I painted the block.
That should be a potent BB. :yesnod:
Old Jul 7, 2002 | 04:43 PM
Merlin522's Avatar
Merlin522
Default Re: My BB update Engine pics :) (1970 Stingray)
Looks awesome Corey!!
Old Jul 7, 2002 | 04:44 PM
bence13_33's Avatar
bence13_33
Corey:
The engine is looking great. I believe you mean the 294 solid lifter cam :D :p:. I'm sure you'll be really happy with your setup.
Old Jul 7, 2002 | 04:51 PM
Corey_68's Avatar
Corey_68
Default Re: My BB update Engine pics :) (bence13_33)
Corey:
Yep, I missed the typo :lol:
It's a 294 w/ .595/.595 lift.
:cheers:
Old Jul 7, 2002 | 07:13 PM
Corey_68's Avatar
Corey_68
Shane, you decide on a intake replacment for the Torker II yet?
Old Jul 7, 2002 | 07:27 PM
bence13_33's Avatar
bence13_33
Corey:
Yepper. I have a Holley Strip Dominator coming in pretty soon. The Strip Dominator is used but it has been professionally ported and gasket matched. The Torker II seems to quit at about 6000RPMs. The cam is designed to go to 6500RPMs and the heads are good for at least that much too. It should perform a lot nicer with a better intake.
What intake are you going to be running?
Old Jul 8, 2002 | 03:43 PM
groovyjay's Avatar
groovyjay
Looks G8 Corey! Wish I had all that cool stuff in my carage!
Old Jul 8, 2002 | 05:34 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Great looking engine!!
What kind of Rocker Arms are you going to use?
:cheers:
Olivier
Old Jul 8, 2002 | 07:42 PM
Corey_68's Avatar
Corey_68
Corey:
Shane
For now I'm going to wait and see if this intake will fit under my bigblock hood, probably not. It's a dual plane off the 454 H.O. If it will not fit, I'm going to go w/ a single plane. Keep me posted with the Holley.
Old Jul 8, 2002 | 07:46 PM
Corey_68's Avatar
Corey_68
Default Re: My BB update Engine pics :) (GrandSportC3)
Oliver
Thanks, just hope it will be pretty as your 383. :yesnod:
I'm running the stock valve covers so I'm forced to run the stock rockers do to the low profile covers. I'm looking forward to seeing those numbers on that stroker motor yours.
:cheers:
[Modified by Corey 68, 5:46 PM 7/8/2002]
Old Jul 8, 2002 | 07:48 PM
GrandSportC3
Oliver
:cheers:
There are certain roller rocker arms that will fit under the stock valve covers. A friend of mine had CRANE Roller Rockers under a 396 Big Block in his 67 Camaro.
I can't wait to get some numbers from the dyno testing!!!
:cheers:
Olivier
P.S. The same friend of mine with the 396 had a polished Torker II Intake on his engine. It was one of the most beautiful engines I've ever seen!!!
[Modified by GrandSportC3, 6:51 PM 7/8/2002]
Old Jul 8, 2002 | 10:46 PM
bence13_33's Avatar
bence13_33
Corey:
You can fit Comp Cams Roller Tipped Rocker Arms under the stock valve covers. That's what I am currently running. Now that I have M/T valve covers I'm thinking of going with the Comp Cams Full Roller Rocker Arm.
Old Jul 8, 2002 | 11:16 PM
Glenn454's Avatar
Glenn454
Nice motor Corey, I'm running stock height valve covers with Comp Cams Pro Magnum roller rockers. Your motor is just like my friends motor.
454
steel crank
7/16 rods
990 REC Port heads, gasket matched 2.25/188 valves
10.2 compression
Gm Dual plane intake
800 DP holley
21/8 side pipe hooker headers
Comp cams 294 solid
Roller rockers
I't pulled 426 rear wheel horse power with open headers.
Old Jul 8, 2002 | 11:34 PM
Darkness's Avatar
Darkness
Default Re: My BB update Engine pics :) (Glenn454)
That looks like it's gonna be mean :reddevil
Good luck :cheers:
Old Jul 8, 2002 | 11:51 PM
Corey_68's Avatar
Corey_68
Thanks :cheers:
Your friend's motor is similar to mine. Is it tuened? The reason I ask is because 426 at the wheels seems somewhat tame for that built motor. That's around 490hp with a 4spd (15% drivetrain loss). True, 490hp is NOTHING to sneeze at but, with that cam and heads I'd figured more. :confused:
I realize a single plane would garuntee more power, but on my Desktop Dyno I seen 593hp with a dual plane and open exhaust. With a single plane and open headers it brings it up to 640hp at 6,500rpms.
With that being said with mufflers your friend is barley making 400hp out of the 454. He has a good cam/heads/carb/and headers, I wonder why he's putting out low numbers?? Or am I overlooking something?? :confused:
Old Jul 9, 2002 | 01:56 AM
Glenn454's Avatar
Glenn454
It's tuned pretty good. He has all new stuff.
MSD 6AL, MSD distributor,40 deg total timing
The Holley is a basic 800DP with the choke milled off. So the carb and the GM intake could be holding him back some. The new Car Craft has a good
article on the 454 HO. They swapped the factory intake to a Performer RPM and picked up 16HP and 9 lb-ft of torque. I was thinking more like 18-20% drivetrain loss on older 4 speed cars. The new 6 speed corvettes probably have 15% loss. Less friction. So 520HP -18% is 426HP. With a new intake and carb I think there's another 25 to 30HP in it. If he realy wanted to make some serious power he should go with a big soild roller and a good single plane intake. Rear wheel dyno numbers can be disappointing.
I watched a 69 chevelle one time on the dyno with a 396 big block chevy. Brodix aluminum heads,single plane intake, Dominator carb, big cam.
He was talking alot of trash! You know how bad it was. I't pulled 300RWHP
It was hard not to laugh!
Old Jul 9, 2002 | 02:34 PM
Corey_68's Avatar
Corey_68
Glen, you are probably right about the % of drivetrain loss. Most likely I'll switch to a single plane, I'm going to have traction problems as it is with 4.11's and a 6spd.
:cheers:
To My BB update Engine pics :)
