Center shift console removal help ? ;)
Old Nov 16, 2013 | 05:01 PM
Cattiva73's Avatar
Cattiva73
Default Center shift console removal help ? ;)
Hello,
I need to removel the shift center console to install new carpet + install a new leather boot and inspect the wires etc under there....how complicated is it?
Could you direct me to an illustrated step by step link if possible?
And what about the shift **** ball...I know there is a spring inside that pops out...
any tricks there???
Btw: I have a 1973 corvette auto.
Old Nov 16, 2013 | 05:24 PM
Karsten's Avatar
Karsten
I just took my new console to the shop that will be redoing the interior. It came with 3 pages of instructions so if no one else has the info I will see if I can't get them back on Monday.
You might also want to check out the Index and Assembly Manual from Eckler's
If you are going to remove the rear E Brake console as well be sure to remove the bolt from inside the center glove box. Remove the cardboard liner to locate the securing the rear of the console.
Karsten
Old Nov 16, 2013 | 06:00 PM
Mooser's Avatar
Mooser
The only really tricky parts are removing the bolt that holds the parking brake console to the rear wall, (access it through the jack compartment)
And the two nuts that hold the center dash cluster to the shift console. The general consensus is going up from the side using a long 1/4 drive ratchet and deep socket, but I've done it with wrenches, (and many flip overs), prefer the socket now days
Other than that it's pretty straight forward
M
Old Nov 16, 2013 | 06:06 PM
Mooser's Avatar
Mooser
Rear bolt suggestions here
http://forums.corvetteforum.com/c3-t...-question.html
Two nuts on the studs holding the center gauge cluster to console, I now prefer Alan's method over my old way
http://forums.corvetteforum.com/c3-t...oval-help.html
M
Old Nov 16, 2013 | 06:13 PM
Alan 71's Avatar
Alan 71
Hi c73,
The bolt for the rear of the e-brake console can be reached from the jack storage compartment.
You might also consider installing the carpet with the shifter and e-brake consoles in place. They need to be loose, (unscrewed), but the carpet can easily be slipped under the sides of the consoles after it has been trimmed. In fact the consoles need to be in place so you can determine how much carpet needs to be trimmed.
If too much carpet is wedged under the consoles the sides of the consoles flare out and the result is a poor fit.
All 4 sides of the front carpet pieces will need to be trimmed to fit.
Here's a couple of pictures from my 71.
Measure, measure, measure!!!!! TRIM ONLY A LITTLE BIT AT A TIME!!!!!
Regards,
Alan
Before any trimming.
Note about 2" maximum extends up under the consoles' sides after trimming.( Compare to first 2 pictures)
After trimming
After trimming
After trimming.
Old Nov 17, 2013 | 07:30 AM
Cattiva73's Avatar
Cattiva73
Originally Posted by Alan 71
Hi c73,
You might also consider installing the carpet with the shifter and e-brake consoles in place too. They need to be loose, (unscrewed), but the carpet easy be slipped under the sides of the consoles after the carpet has been trimmed. In fact the consoles need to be in place so you can determine how much carpet need to be trimmed.
Regards,
Alan
After trimming
After trimming
After trimming.
Thank you. I think I,LL just do the same��
To Center shift console removal help ? ;)
