trickflow head for low compression 350
Old Nov 27, 2013 | 10:35 AM
  #101
billla's Avatar
billla
St. Jude Donor '14
Harry, you're doing just fine - don't take one comment too hard. You're asking good questions and getting good answers. It's a lot to sort through.
We all recognize that it's hard to sort through differing opinions based on differing experiences, but I'm confident everyone here is trying to help in the best way they can. Your situation is somewhat unique, so there's some "spirited" discussion - but it's all intended to help you learn what you need to know to make a good decision
I'm 100% confident you'll be faster next summer
Old Nov 27, 2013 | 10:45 AM
  #102
bluedawg's Avatar
bluedawg
I wouldn't sweat it. I've never understood why forum members invest there emotions so. Cardo seems to be a good dude and adds a lot of value to the posts that I've seen his participating in.
Old Nov 27, 2013 | 11:24 AM
  #103
REELAV8R's Avatar
REELAV8R
Originally Posted by Flyinace3
A 400hp 350 does not count as a near championship build in my book.
As for setting the advance curve yes I can and have done that.
Carb setup and adjustments only on 2 stroke snowmobile engines.
Internal engine work on a automobile engine. No I do not have any experience but I have been through a few 2 stroke engines.
I have not decided on what heads I will buy so where does the comment he going to buy the most expensive heads on the market come from?
Yes I am going to build a 383 in the future....but I am currently building a 350 that I would like to have approx. 400hp so where should my budget be? I never set a budget nor am I on a low budget. But there is no point in buying parts that are not intended for the power level I am trying to achieve. the reason for this build is to get my car to be quicker for next summer and to save some time this winter for other items I am doing to the car as well.
the cams I referenced are from each of the cam companies tech departments that I contacted with the same build specs. Not cam That I selected...but I believe that was is my post.
As for my mechanical ability and knowledge I am a journyman tool & die maker enuff said.
I come here looking for advise and knowledge from the guys that want to share what they know, their opnions, what works and what doesn't,ect.
I usually only post when I have something of value to add to the thread, if I don't know I listen and try to learn. So yes my post count is low since I am not a corvette expert and I don't know everything.
My Name is Harry and I apologize if I offended you in any of my posts that is and was not my intentions.
I will work on filling out my profile
Harry, last year I was in your boat as well. I had experience building engines, but only stock overhead cam type rebuilds and two and for stroke bikes. This last year was my first V8 push rod type engine performance rebuild. The performance thing gets difficult because you have never had to purchase non stock components and make them work with other non stock components. Se there are many descisions to be made along the way.
Guys like Billa and Makko63 have been doing this for a long time and know what works for them. They don't necessarily agree with what works, but they each have their own experience so you're going to get varying opinions.
The basics for all engines are similar. The push rod thing is different but not hard just got to make sure geometry is right.
I decided to get the Dart SHP 180cc heads with 64cc chambers as my first endeavor into this performance building thing. I also decided to get it with valves and springs installed so that was one less thing I had to set up. They were cheaper than the AFR's and can support 400HP easily. I can't highly recommend them and won't use time on my build for my 406, but they were good starters.
The heads you were originally looking at look like good starter heads to me. The AFR's came up as an option only because it was mentioned that a 383 was in the future, then things went a bit a stray from there.
I read the books recommended in this thread before I got started and they helped tremendously.
I spent 6 months just trying to figure out cams so I could hopefully get it right the first time. And it paid off. I got a 350 that performs very well and is still very streetable.
Keep up with the questions you'll get all kinds of advice then choose which you want for your build and move on. Just do your home work so you know why you should choose a specific component. Taking advice blindly without understanding is not something I have ever been comfortable with or would recommend and may lead to further confusion later when another decision needs to be made that hinges on the prior ones.
Cardo is a good guy don't take his post too hard. We all get frustrated at one time or another.
Old Nov 27, 2013 | 01:05 PM
  #104
Flyinace3's Avatar
Flyinace3
Firstly I want to apologize to cardio that I took your post too personally. Your post about building a3 legged dog that won't start moving until 5000rpm is what I want to avoid and the reason I started this thread
These are the heads I am going to purchase
Old Nov 27, 2013 | 01:08 PM
  #105
Flyinace3's Avatar
Flyinace3
These are what I am planning to purchase.
http://m.ebay.com/itm/321260921779?nav=WATCHING&sbk=1
Old Nov 27, 2013 | 01:44 PM
  #106
billla's Avatar
billla
St. Jude Donor '14
If that's the actual link...those are bare heads; no valves or springs.
Old Nov 27, 2013 | 02:59 PM
  #107
Flyinace3's Avatar
Flyinace3
Originally Posted by billla
If tha the actual link...those are bare heads; no valves or springs.
Yes.
I am going to send them to Eric Weingartner to setup the valves, cleanup and flow bench them.
Springs. Retainers lock I will source after ggetting the cam I am going to use.
Old Nov 27, 2013 | 03:06 PM
  #108
Flyinace3's Avatar
Flyinace3
They are angle plug heads so they may interfere with my headers.
There looks to be plenty of room behind the primary tubes for the sparkplugs. We will see
Old Nov 27, 2013 | 06:01 PM
  #109
diehrd's Avatar
diehrd
For a stock bottom end motor , I would get the specs of a GM Crate ZZ4 , get a set of used L-98 heads , match cam specs intake and carb and be close to 350 hp on a budget that is pretty low and you can be sure of the hp numbers.
Then keep on keeping on towards the 383 or whatever you really want to do in the future .
Old Nov 28, 2013 | 06:17 AM
  #110
76strokervette's Avatar
76strokervette
There is a write up online of a set of dart shp heads that Eric Weingartner ported.He turned them into a pretty impressive head flow wise.I do know that he also sells pro-filers and ports them.Just food for thought.I hope to get back to work on my shp 400 build this weekend.If you want I'll post pictures of side pipe headers mounted with the plugs installed.Good luck with your build.
Old Nov 28, 2013 | 01:39 PM
  #111
Flyinace3's Avatar
Flyinace3
Post the pics. My heads should be here next week. I'll post pics before and after I get the work done to them.
Old Dec 4, 2013 | 07:50 PM
  #112
76strokervette
Picture is posted on my build thread if you're curious.
Old Dec 6, 2013 | 07:36 PM
  #113
Flyinace3's Avatar
Flyinace3
Update
Heads were delivered today.
I decided to go with the heads Chris Straub sells. I decided to get bare heads beacause I am unsure if I am going to use a flat tappet or hyd roller cam. Now I will start looking in to who I will have complete these heads, Hone the guides, valve job, gasket match, flow bench, ect.
Old Dec 6, 2013 | 08:34 PM
  #114
7t9l82's Avatar
7t9l82
excellent choice. that is the best way to do it. see if you can find someone who will assemble them when you pick them up.
