Can I pull plug wires
Old Nov 22, 2013 | 11:07 AM
Camivette's Avatar
Camivette
Default Can I pull plug wires
78 with HEI. I'm chasing a possible miss and would like to pull the plug wires one at a time at the cap to search for a miss. Thanks
Old Nov 22, 2013 | 11:25 AM
MelWff's Avatar
MelWff
No, do not do that, you can short out the module in the distributor. With the engine off you can pull a wire at the plug and ground it and then restart the engine.
Old Nov 22, 2013 | 11:26 AM
7T1vette's Avatar
7T1vette
Sure. It will run a bit rough, of course; but you can compare how it runs 'before' and 'after' each plug cap removal to detect which line is the one with the problem. If you find one that eliminates the "miss", just make sure that you check the plug, the wire, and that specific contact in the distributor cap to find where the problem is located.
Note: After removing each plug cap, place it somewhere so that the opening is at least an inch or two from any grounded surface. Otherwise, it could 'leak' its spark out of the cap and mess up your testing.
P.S. I don't think you want to 'ground out' the removed plug wire. Keeping it "open" (away from metal) is no different than having a completely fouled plug....no spark will occur. Don't know how that will cause a problem for the module.
Old Nov 22, 2013 | 11:28 AM
gcusmano74's Avatar
gcusmano74
Very high voltage there. Wear gloves. It may "bite" you anyway. If it does, you will be startled, but there is not enough amperage in a stock ignition system to hurt a healthy person.
Old Nov 22, 2013 | 12:29 PM
7T1vette's Avatar
7T1vette
If you try to do that with a running engine, put on latex/plastic gloves and then a set of leather gloves to protect from heat. But, I would just turn engine OFF between tests.
Old Nov 22, 2013 | 12:41 PM
Snoopysvet's Avatar
Snoopysvet
Did not know that.
Could be the coil too!
Old Nov 22, 2013 | 08:20 PM
Shark Racer's Avatar
Shark Racer
Getting zapped by HEI is "surprising" though. Feels almost like getting stung.
Old Nov 22, 2013 | 11:24 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Fouled plugs often have electrically conductive (carbon) deposits on the insulator (between the center electrode and the threaded body. This shorts out the high voltage/current coming down the wire (similar to grounding the plug wire), preventing an ignition event in that cylinder.
Where possible damage can occur is when the plug wire is open circuited. The coil secondary voltage keeps climbing (as the magnetic field collapses) in an attempt to jump the plug gap, which in this instance is not a .035" gap but actually a very large gap (perhaps an inch or more). While the secondary voltage is going sky high (tens of thousands of volts) at this moment, the primary voltage at the coil C- terminal (which is also the collector of the switching transistor in the HEI module) is also seeing multiple hundreds of volts due to the primary to secondary turns ratio of the coil. The switching transistor in an OEM HEI module is a good robust item, but it's best not to abuse the system unnecessarily.
Old Nov 22, 2013 | 11:41 PM
billla's Avatar
billla
St. Jude Donor '14
It's a lot easier to just take an inductive timing light and move the pickup to each of the wires, looking for one that doesn't have a steady strobe.
Old Nov 23, 2013 | 03:11 AM
iokepakai's Avatar
iokepakai
Found a bad plug by using an IR temp gun.It was a brand new plug ,that went bad.Cylinder was cooler than the rest.Changed the plug no more miss....
Old Nov 23, 2013 | 03:17 AM
bluedawg's Avatar
bluedawg
I've used a timing light and found misses, some times thats enough, other times I've found that removing the plug wire works, but also found it easier with a set of plug wire pliers with insulation to avoid getting shocked.
Old Nov 23, 2013 | 10:33 AM
Camivette's Avatar
Camivette
Yes Billa I myself have said that to others. My light just bit the dust and I'm waiting to get a good one with tach instead of another basic one.
To Can I pull plug wires
