which is better?
Old Nov 22, 2013 | 02:44 PM
Cattiva73's Avatar
Cattiva73
Default which is better?
Well my pressure oil line started leaking AGAIN right behind the oil pressure gauge!..I changed the fittings before this summer and no problems.
This time I caught it in time before the mess....
my question:
-should I replace the line with the plastic kit ones
-or try again with new fittings?
I dont know how reliable these things are and Im about to put new carpet in the car....I dont want to worry about it leaking ever again!
Thoughts?
Old Nov 22, 2013 | 02:47 PM
Kacyc3's Avatar
Kacyc3
Switch to electronic would be my solution.
Old Nov 22, 2013 | 02:49 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Mine is plastic. The only time it has ever leaked was when I forgot to reconnect it.
Old Nov 22, 2013 | 02:54 PM
69FASTFUN's Avatar
69FASTFUN
You didn't tighten it enough to crimp the ferrule onto the tubing so it will seat in the fitting on your gauge.
Old Nov 22, 2013 | 03:02 PM
Alan 71's Avatar
Alan 71
Hi C,
I agree that the ferrule needs to be in good condition and in the proper position on the pressure line for the fitting to compress it well and prevent a leak.
Regards,
Alan
Old Nov 22, 2013 | 03:21 PM
C2C3PO's Avatar
C2C3PO
I was not aware that the line from the block to the gauge cluster was copper?
On my 72 only the short length near the exhaust manifold is copper then it transitions to plastic.
Knowing just "how tight" to tighten those ferrules is really difficult to explain. The copper is such a soft metal that the difference between under-tightening and over-torquing is small.
Unless you're absolutely sure you didn't already distort the ferrule I'd start all over again with all new pieces.
Old Nov 22, 2013 | 06:18 PM
hugie82's Avatar
hugie82
You have to replace the compression fitting if you've taken it apart a few times and is the block its screwing into the correct fitting?
I've run copper fittings for years in my 4x4 67 Chevy truck with very hard use and never had it leak.
Old Nov 22, 2013 | 08:08 PM
DC3's Avatar
DC3
Shortly after I bought my '73, my plastic oil line broke in the engine compartment. I lost most of my oil before I knew what was happening. I'd hate for it to have broken inside the cabin.
My first solution was to use a nitrous oxide hose. I had to source some fittings to get that to work but it worked very well. After I did that, I discovered Auto Meter makes a stainless braided hose that would have worked.
Since then I've converted to all gauges to Auto Meter and so mine is now electric.
DC
Old Nov 22, 2013 | 10:18 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Try to keep the mechanical gauge if you can, although an electric gauge could be adapted to look original as long as the needle had the same amount of swing.
I just checked the copper set-up on the project car I recently bought----the first sign of a drip--it gets re-done with nylon tubing.
You can get "heavy duty" nylon tubing and an adapter fitting for the back of the O/P gauge and one for the block.
Just make sure to keep the nylon line away from hot metal & sharp edges (same rule for copper)----it should last a couple generations (keep an extra piece of tubing & 2 o-rings which you'll never need) stashed in the car just in case.
Old Nov 22, 2013 | 10:33 PM
Hammerhead Fred's Avatar
Hammerhead Fred
100%
Two of my cars are still running the original plastic lines with never an issue and I've disconnected them from the gauge several times over the decades that I've had them.
Old Nov 22, 2013 | 10:43 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Most of the plastic/nylon line and will dry and crack from heat over time. Once a copper line is installed properly with a good ferrel and proper pressure to seat it, it will not leak unless recklessly disturbed.
Old Nov 22, 2013 | 10:45 PM
Cattiva73's Avatar
Cattiva73
Default electric gauge?
I like the electric gauge idea....
Has anyone done it? if you have a picture of the electric gauge show me please
Old Nov 22, 2013 | 10:47 PM
Cattiva73's Avatar
Cattiva73
doorgunner,
Where should I look for an electric gauge?..and is it complicated to connect?
Old Nov 22, 2013 | 10:52 PM
RickyBerg's Avatar
RickyBerg
In 1974 the Corvettes got an electric oil pressure gauge.
You will find them on Ecklers and so on.
http://www.ecklerscorvette.com/catal...ssure&x=23&y=6
Old Nov 22, 2013 | 11:01 PM
Cattiva73's Avatar
Cattiva73
Thanks,
I have a 1973 Corvette...will the 1974 gauge and sender work for my application?
Old Nov 22, 2013 | 11:08 PM
RickyBerg's Avatar
RickyBerg
Yes it will slip right in.
I have it on my 1972 and the only miss-match is that the figures on the gauge are white rather then pale blueish like the rest in my 72.
Old Nov 23, 2013 | 10:03 AM
Easy Mike's Avatar
Easy Mike
FWIW: A replacement plastic oil pressure line would be quicker and cheaper.
To which is better?
