transmission swap
Nov 24, 2013 | 01:20 PM
7th Gear
transmission swap
I would like to find out what is involved in a 350 to 700r4 swap in my 76?
Nov 24, 2013 | 02:13 PM
you can reuse the tranny yolk ,and shorten the drive shaft a little .you will need a TV cable and the bracket to mount the TV cable to the carb.holley makes the TV bracket .B&M makes a converter lockup switch kit .shift works makes the shifter gate to convert your current shifter .get a corvette servo for the 700r4 you install.you will need the correct speedo gear in the tranny tail shaft to keep your speedo accurate .they are a couple or companies that sell the conversion kits .
Nov 24, 2013 | 09:02 PM
Thanks garygnu.....I needed the same info.
Will the transmission crossmember need to be modified/moved....... since the 700R4 is a little longer?
Nov 25, 2013 | 07:20 PM
Nov 25, 2013 | 09:30 PM
Bowtie Overdrives makes a nice bolt in cross member for this swap.
Apr 9, 2015 | 10:33 PM
7th Gear
350 swap to a 700r4 in a 76
does anyone know how much I have to shorten up my drive shaft?
Apr 10, 2015 | 03:56 AM
Quote:
Originally Posted by
kenny76
3 inches.
Apr 10, 2015 | 07:21 AM
7th Gear
PcolaPaul
3 inches.
Apr 10, 2015 | 07:42 AM
It should be mentioned that I read the 200r4 like the ones used in the monte carlos will fit without any driveshaft or crossmember mods...
Apr 10, 2015 | 08:45 AM
7th Gear
augiedoggy
Already have a 700r4 rebuilt & ready to swap out
Apr 10, 2015 | 11:22 AM
I used the Bowtie Overdrive crossmember in my 75 for my 700r4, perfect fit, nice product. And were helpful on the phone with tech questions.
Apr 10, 2015 | 12:10 PM
Aquarian
Apr 11, 2015 | 12:00 PM
7th Gear
havesometo
I have the same crossmember ready to install
