72 OEM Coil
Old Apr 8, 2015 | 01:54 PM
Mystic195's Avatar
Mystic195
Default 72 OEM Coil
I am going thru a 72 454 that I bought and replacing the coil. There is some discrepancy in the catalogs on what color the original coil is. The one on the car is black on top and bottom but the replacements are all black on top and gray on the body. Does anyone know what the correct color is?
Is there a better option than the stock one?
Old Apr 8, 2015 | 02:48 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
stock all Black.
Old Apr 8, 2015 | 02:52 PM
Alan 71's Avatar
Alan 71
Hi m,
I believe the original coils had the 'can' painted black while the top was black bakelite. I'm not sure if it was painted or not. My guess would be it wasn't.
Regards,
Alan
You beat me 69V while I was trying to figure out how to spell bakelite.
Old Apr 8, 2015 | 05:40 PM
Mystic195's Avatar
Mystic195
Does anyone know where to get one at, or a part number? I ordered one from ecklers and it came with a black top and gray can.
Old Apr 8, 2015 | 06:16 PM
Red Vert 02's Avatar
Red Vert 02
I bought one for a small block from NAPA a couple of years ago and it had the black can. Check their web site and see if there is a pic of the currently available coil.
Old Apr 8, 2015 | 08:46 PM
dan1495's Avatar
dan1495
Most of the Corvette parts suppliers sell a reproduction of the original, but they aren't cheap. The Oreillys house brand coil is all black and costs around $20.00.
Old Apr 10, 2015 | 01:16 AM
7T1vette's Avatar
7T1vette
Paint the 'gray' can on the new one with semi-gloss black. Only the can is painted; the bakelite top is not. That would be your simplest fix.
Old Apr 10, 2015 | 04:46 PM
redrdstr72's Avatar
redrdstr72
FWIW, I believe the reproduction coils are "canned over", showing the embossed ID, to replicate original. The problem with this is that the original screw will not reach from one side of the coil mounting bracket to the other, due to the larger diameter of the repro coil. If complete originality or judging is important to you, you'll want to know that while the repro coil looks nice, the use of a longer screw will be a give away that the coil is not original.
Hope this helps...
Old Apr 10, 2015 | 05:55 PM
augiedoggy's Avatar
augiedoggy
ALL coils of this type are now made overseas regardless of color or markings.... If its important to you, searching ebay for NOS (new old stock) would be one way you may find a real one.
Old Apr 11, 2015 | 12:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
To 72 OEM Coil
