I have owned this car for about 3 month's (my first Corvette). Something I have learned is the previous owner had a habit of simply removing "unnecessary" items as they broke. So I have a couple of questions.
The first question, did this car originally come with a radiator overflow containment system? There is not one currently on the car and the owners manual seems to suggest some cars had them and some did not as it gives instructions for properly filling the radiator for both systems. Currently the vent tube (below radiator cap) just drains to the ground.
Second question is there is a hose that comes out of the firewall that has been cut off (see picture). What did this hose attach to?
And yes I have the AIM, sometimes it's really useful and sometimes I'm still trying to figure it out.
In those two instances, the PO did not 'bubba' anything, they are both correct.
The hose that looks cut, is not cut, it's the vent for the wiper safty valve in the wiper bay. The valve makes sure that the wiper door does not close until the wipers are in the parked.
I have a 72 with AC, and at least in 72 AC cars did not have an overflow, it has the same release drain to the ground.
No Corvette prior to 1973 had an overflow container. Depending on model year, engine option and presence of A/C, some cars got a copper/brass rad with integral cap and some cars got an aluminum rad with no cap but paired with a pressurized expansion chamber.
Both types overflowed via a hose to the ground if overfilled.
Hi ice,
It looks like a nice car in your avatar.
350/350, 4-speed, a/c, is a VERY nice combination!
Maybe a few pictures for us to enjoy?
Regards,
Alan
I've read that it was mind control propaganda. The tach for the 72 LT-1 air cars had an intentionally low redline to decrease the chance of throwing the belt at the higher RPMs of the previous two model years.
