New heads Pics
Old Dec 10, 2013 | 09:31 PM
Flyinace3's Avatar
Flyinace3
Default New heads Pics
These are the heads I bought from Straub tech.
185 with 65cc chambers.
I bought them bare since I was still undecided if I was going to use a flat tappet or hyd roller cam.
I will be sending them out to get the finish work done and some mild porting and post the before and after flow readings
Advertise flow readings
Lift Intake Exhaust
.300 202 145
.400 235 175
.500 241 185
.600 248 190
Old Dec 10, 2013 | 10:35 PM
7t9l82's Avatar
7t9l82
definitly needs some clean up, but you have a good start. and thats the right way to do it
Old Dec 11, 2013 | 12:51 AM
gkull's Avatar
gkull
I would send the intake along and have it port matched. Save yourself some later grief and have them install "Time Serts"
http://www.timesert.com/
In the 4 head valve cover bolt holes.
Use the rubber/silicone cover gaskets with the metal inserts.
Manley race flow valves with tulip stem valves with radius heads.
If those came with 2.02 seat size have them open up the seats to 2.05 or 2.055 valves. The valve size is what determines the final flow for any given port.
Old Dec 11, 2013 | 07:17 AM
76Rat's Avatar
76Rat
Repair the threads before they break? How about installing a set of studs into the valve cover holes instead.
http://www.summitracing.com/parts/ar...7613/overview/
Studs with 12 point head nuts. They work great.
Old Dec 11, 2013 | 08:39 AM
Flyinace3's Avatar
Flyinace3
I am planning using header studs but didn't think about valve cover studs, great tips.
Old Dec 11, 2013 | 09:11 AM
Solid LT1's Avatar
Solid LT1
Looks like something from overseas.......where are they made? Combustion chamber doesn't follow current designs for 23 degree cylinder heads. I love it when a customer brings in a bunch of Internet purchases for our shop to build into a "Killer Motor". I just had a customer bring in a bunch of "Trick" LS engine parts...60% weren't useable! We built him a haul *** 408 using his LS2 block with LS3 heads and it passes state smog checks. Lucky for this guy a lot of parts were recent purchases and he could get them exchanged through "Dumbsh*t Racing" but with shipping charges he probably wasted $300 on the build.
Old Dec 11, 2013 | 09:32 AM
Flyinace3's Avatar
Flyinace3
I
These heads have centerbolt and perimeter valve cover patterns. Is there a preference to which is better to use?
Head are cut for 2.02 valves. Are there any downfalls with a 2.05 valve? Engine is the gm Goodwrench 260hp with dished 4vr pistons, would the need the reliefs cut larger to accommodate the 2.05 valve?
Old Dec 11, 2013 | 09:51 AM
gkull's Avatar
gkull
Well it is like this. If you have ever been around high end aluminum heads they are actually sold with steel thread inserts. cheap heads you have to add them. The second thing is high end tall valve covers made to clear roller rockers and tall studs use something like 4 inch long bolts. Not little short studs
http://www.summitracing.com/nv/parts...make/chevrolet
Old Dec 11, 2013 | 10:39 AM
682XLR8's Avatar
682XLR8
Interesting....never heard of these before. Thanks for posting the link George
I installed heli-coils on my Brodix heads when I first got them just to avoid problems later, also installed them on my EFI intake on the thermostat housing holes and the distributor hold-down
Next time I buy a set of heads I'll have to remember those timeserts
Old Dec 11, 2013 | 11:07 AM
qwank's Avatar
qwank
time serts are awesome, I use them at the shop all the time to repair threads.
Old Dec 11, 2013 | 11:39 AM
gkull's Avatar
gkull
The difference between .02 and .05 of course is radius is 1/ of the diameter. I would not worry about a change of .015 inches. All they have to do is grind the seats so the 2.05 valve fits down in flush.
I've never had center bolt valve covers
Old Dec 11, 2013 | 11:43 AM
gkull's Avatar
gkull
helicoils.......... ever dorked one up? years ago I was researching alternative better products and I came across time serts. That is all the race shop uses.
the distributor hold-down use a stud lock tighted in
Old Dec 11, 2013 | 11:49 AM
76Rat's Avatar
76Rat
I'm sorry. I guess the ones that I use must not be as high end as yours.
http://www.jegs.com/i/Granatelli/467/GM-SBC102/10002/-1
Old Dec 11, 2013 | 12:13 PM
682XLR8's Avatar
682XLR8
Yes I have....pull it out, clean the threads and install another one
I know they're not fool-proof, but when I installed them 6-7 years ago it was the only option I was aware of....now I have that Timesert page bookmarked
Old Dec 11, 2013 | 12:20 PM
Flyinace3's Avatar
Flyinace3
I don't know who or where they are made I would say overseas though.
What is different with the chambers compared to current 23 degree cylinder heads?
Application = mild 350 street
Old Dec 11, 2013 | 04:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
For a mild goodwrench motor upgrade those will be a nice wakeup for sure.
Dont know that putting race stuff in them is even worth it. The timeserts gotta agree with. Nothings worse than torquing down your intake or valve cover and having the threads fail when youre about to take off to cruise night an hour later.
Chamber may not be cutting edge but its not bad either. Almost looks like an older Dart/Edelbrock copy leave the chamber alone
Old Dec 12, 2013 | 11:56 PM
Solid LT1's Avatar
Solid LT1
Those chambers are big and open like a old state of the art 292 Turbo head from the late 1970s early 80s most heads have a laid back chamber by the intake valve with a smaller opening by the exhaust valve to create turbulence and fuel mixing when piston approaches TDC. Looking at those chambers took me 30years back in time. I'm not saying they are bad just not current design philosophy.
Randy if you ever need some Timeserts any time day/night give me a call all the tooling down at the machine shop, run down here and we'll fix you right up.
To New heads Pics
Old Dec 13, 2013 | 12:04 AM
682XLR8's Avatar
682XLR8
I sure will, thanks!
Old Feb 25, 2014 | 03:38 PM
Flyinace3's Avatar
Flyinace3
Update.
I dropped the heads off today
For steve Sanchez at total flow products to setup and machine.
Work being done is guides honed, valve job, bowls blended and cleaned up.
Clean up ports, mill deck to achieve 60-62cc chambers and bench flow.
I will post flow numbers and photos when they are complete.
Old Feb 25, 2014 | 06:40 PM
7t9l82's Avatar
7t9l82
have your guy screws a spark plug in and see if it is out into the chamber.
