Electric Fuel Pump Conversion
The fuel dripping into the engine is not from the electric pump. It could be a number of things:
1 trash/material in the needle & seat - need good filter
2 worn needle & seat
3 fuel pressure too high
4 float setting too high
5 percolation - fuel boiling -
Do you have a fuel return???
What type of carb???? It makes a difference on if a fuel filter can be installed in it or not.
DO you have a fuel filter installed.....of so...where is it installed.
If you remove the fuel pump...you HAVE TO have that fuel filter sock in the tank to catch the primary crap that can be in the tank. Getting a 1978-1981 sending unit is ready to go. DO NOT try to install a paper element filter in the tank. Not a good idea...I have seen it done and it does not work for long.
Does you fuel tank...after you have driven it...get pressurized...so when you go and remove the fuel cap...it has pressure that is released when the cap is removed. I have encountered cars that leak fuel due to the vapor return line is plugged...and the fuel cap is designed to allow air in...but not out. So the tank gets pressurized and it can leak pasty the needle and seat if the pressure is high enough. I have had carbs dripping and when I go and remove the fuel cap...the dripping stops instantly...and the pressure in the tank was rather severe due to the baby powder I placed around the fill cap...blew and put baby powder dust in the air around the fill cap.
DUB
One thing that has not been touched on in this discussion about fuel return is WHERE to have the fuel return.
I prefer on a C3 is to have the fuel return at the mechanical fuel pump area like the factory had originally. On the new Corvettes...they only have one fuel line going to the engine because the fuel filter has the return in it and it is back in the rear of the car...and this is fine BECAUSE GM has taken steps in adding heat shielding and what have you to better protect the fuel line from heat...versus the C3 era.
I am not a fan of a fuel line that I can infra-red thermometer check and it is hot as all get-out....that allows fuel to linger in it because the fuel return is way back in the rear of the car. UNLESS steps are taken to protect this fuel supply line from heat...and most people do not do this...especially when headers are installed and the performance changes. I have had two Corvettes in my shop and are basically the same except for one having headers and drive them the same amount of time and distance and the temps on the frame where the fuel line is secured is much higher than the engine with cast iron manifolds.
I know it may be a bit paranoid...but some changes I applied to many C3 Corvettes due to a high heat issue on the fuel lines helped out. Kinda like a starter blanket on your starter when you change to headers...regardless if they have a coating or wrap on them or not...it can aid ina possible problem in the future.
DUB
