Water Pump failure?
Old Dec 17, 2013 | 01:43 AM
79vetter's Avatar
79vetter
Default Water Pump failure?
I have a leak around the water pump but I can't see where its coming from. The hoses and clamps are nice and tight . If I watch it at idle I don't see it coming from anywhere but if I drive the car then park it I notice it fairly wet down by the pump. I am wondering if its coming out of the weep hole on the pump. I tried to put my hand on it but can't feel it.
The car is not over-heating at all but i have noticed a sqeaky sound at idle.
Perhaps the pump is still functional but close to failing? How can I verify this?
thanks
Old Dec 17, 2013 | 05:17 AM
M-yellow01's Avatar
M-yellow01
I think you are spot on with your diagnosis. I went though the very same situation with a 78 vette that I had a few years back. Turned out to be the water pump leaking at the weep hole, position so low under the shaft.
Old Dec 17, 2013 | 06:43 AM
mds3013's Avatar
mds3013
The lower weep hole is very difficult to see on a C3. An inspection mirror can help. I had to tear mine down to verify the source of the leak. If you have nothing better to do look through the link. mike...
http://forums.corvetteforum.com/c3-g...alt-mines.html
Old Dec 17, 2013 | 09:29 AM
63vette427's Avatar
63vette427
I went through the same thing. I changed out the water pump and solved the problem. It's not a hard repair and I'm sure you will find that that's your problem as well.
Good luck..
Old Dec 17, 2013 | 04:17 PM
79vetter's Avatar
79vetter
Mike- is there something special about a water pump / pulley on L-82s that causes them to fail?
Old Dec 17, 2013 | 07:16 PM
mds3013's Avatar
mds3013
No, not a failure problem. The housing needs to have the correct clearance. You can see the terrible looking quality of the GM pump made in China. NAPA has the best new pumps. At least they did for my '77. I still did a little smoothing of the surfaces on the NAPA pump. mike...
Old Dec 17, 2013 | 10:03 PM
Ironcross's Avatar
Ironcross
if it starts to push water out in a serious fashion, loosen the cap to the first notch to relieve the pressure...that way you could drive for miles and miles and never heat up as long as the fluid was ok
Old Dec 17, 2013 | 10:35 PM
79vetter's Avatar
79vetter
Well I am kinda disappointed because I was expecting the weep hole to be wet - it was bone dry.
There is a freeze plug in the neighborhood and it looks wet but I poked it with a screwdriver and it seems to be tight.
Old Dec 19, 2013 | 09:26 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Maybe the gasket on the rear plate of the WP is leaking then? Not easy to tell while mounted and if you already know that the t-stat housing is not it.
Just throwing out possibilities...
Old Dec 19, 2013 | 09:56 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
How old is the waterpump?
Stick a 3" long piece of tight-fitting clear tubing in the weep hole/plug the lower end of the tube to hold any leaked fluid from the weep hole...it will be soaked if it's the leak source.
Check the bolts on the rear cover...maybe tightening them will help.
Old Dec 29, 2013 | 12:18 PM
79vetter's Avatar
79vetter
I still have the mystery leak...
The water pump is about 7 yrs. old but only about 1500 miles on it. The bolts/seal on the back of the pump are not wet at all.
I ran a test: I let the car idle for 30 mins while I stood there with a flashlight - not a drip. Then I go drive the car and after a little while I can see smoke from the coolant hitting the headers.
I get home - the following items are wet: A/C compressor, both hoses at water pump and the front of the block on pass. side and on downward.
Question: If its leaking out the weep hole would the coolant get sprayed around the different places by the cooling fan/air flow?
Would UV Dye in the coolant be worth trying?
thanks
Old Dec 29, 2013 | 02:22 PM
mds3013's Avatar
mds3013
Fan and airflow through radiator while driving can spread the coolant everywhere. No need for UV dye. Rinse or dry everything. Go for a short drive and come back home. Drive slow to keep spreading to a minimum. Look for evidence of leak. If none found, go for a couple of more miles and do the same. Sometimes a coolant leak will show itself during the cool down period. Just have to keep trying and you will eventually find it. Mine was leaking from the TVS threads on the thermostat housing. Since there was coolant on top of the housing then I knew where it was coming from. Would not leak under pressure and temp.. When the car sat for about a week when stone cold then it would leak. Good luck with it. mike...
Old Dec 29, 2013 | 08:06 PM
lvmyvt76's Avatar
lvmyvt76
make sure the belts are not too tight, this will wear one earlier in their life.
Old Dec 29, 2013 | 09:18 PM
damoroso's Avatar
damoroso
If you want to add to your tools, this would be a great time to get a pressure tester, or maybe find a friend with one? Maybe the parts store will lend you one. Using one of these will make tracking this down really easy...
Old Dec 29, 2013 | 09:36 PM
RU7376vettes's Avatar
RU7376vettes
Look around the upper mounting bolt boss area. I have had two GM Performance Products Water Pumps develop a small crack in the bottom of the boss. It appears that the wall thickness between the water passage and the boss is too thin. The other place to look is the lower hose to pump connection. Some of the hoses are fairly large compared to the pump inlet. Even with the clamp tight, they may leak.
Unk
To Water Pump failure?
