taking engine out with headers attached ?
Old Dec 26, 2013 | 05:37 AM
Belgian1979vette's Avatar
Belgian1979vette
Default taking engine out with headers attached ?
Is it possible to take an engine out of a c3 with the headers attached ? I assume no, but maybe someone tried this and has found a way to do it.
Old Dec 26, 2013 | 06:57 AM
7t9l82's Avatar
7t9l82
not with long tubes, shorty headers will.
Old Dec 26, 2013 | 09:47 AM
scottyp99's Avatar
scottyp99
Even if it were possible, I don't know why someone would bother to try, it's just 12 bolts to remove them.
Scott
Old Dec 26, 2013 | 10:57 AM
lars's Avatar
lars
No, you can't. You have to drop the headers to get the engine out, along with the fuel pump, in most cases.
Lars
Old Dec 26, 2013 | 11:42 AM
Belgian1979vette
Scott
Simple : I had a hell of a time getting them on and even that was when the body was off the car. I cannot imagine what it will be like with the body and everything on the frame.
Anyway this confirms what I was thinking.
Old Dec 26, 2013 | 05:02 PM
scottyp99's Avatar
scottyp99
The usual procedure is to unbolt the headers, and secure them somehow, then lift the engine out. When you put the engine back in, you drop it in and re-attach the headers. It's not the same as installing headers with the engine in the car, which can be difficult (as you well know, apparently!)
The fuel pump kinda sticks out, and should be removed, as Lars suggests. Even if the engine can be physically removed without removing the fuel pump, it is relatively delicate, and can be damaged during removal of the engine. The same goes for the distributor and carb.
Scott
To taking engine out with headers attached ?
