Could anyone give me an idea of how much it would cost to have a complete transmission oil seall kit installed for transmission. I recently discovered drops of fluid just right of center on floor.
There are some seals/gaskets that you can replace (or have replaced) while the transmission is still in the car: pan gasket, rear output seal, speedo plug seals/O-ring, shift shaft seal, dipstick tube O-ring, modulator O-ring (if you have a vacuum modulator), and governor cover gasket.
However, you cannot change the input oil pump O-ring or the input pump seal without separating the engine and transmission.
Your best course of action is to clean the transmission off well so that you can determine exactly 'where' the leakage(s) occurs. Once you know where a repair is required, you can address it.
If your transmission has a LOT of miles on it, you might be better off just swapping your transmission for a similar unit that has been completely rebuilt; or have your unit rebuilt. But, if you have leaks that can be repaird "on the car", just do them yourself.
Don't forget- some cars had a TCS switch that is in the 3rd gear pressure port. The switch can leak also. And the location is real close to the dipstick on a TH350. Close enough it looks like the dipstick tube is the source of the leak.
As for myself....I would rather buy a good repair manual/do the work myself....then use the "savings" to get those parts for the car that keep it looking new! That's why I built my own sandblasting cabinet for $100---it will be used to clean/restore original parts that would otherwise need to be replaced for cosmetic reasons (the $400 savings will be used to replace missing chrome parts on my project).
And to think---my first DIY was.....changing the oil & filter.
