Corvette starter details - constant problems
Old Dec 27, 2013 | 01:26 PM
buba6's Avatar
buba6
Default Corvette starter details - constant problems
Guys, once again I need your help!
I have my car almost ready, but have constant problems with my starter... I have broke two already and beeing in Poland and ordering them in USA pushes me back for a month every time. So my problem is that after couple engine starts it starts to ratle and the inside of the starter is broken. I think that I have ordered the first one wrong, probably it has the wrong numer of teeth. Can any of you check the numer of teeth on the gear of the starter?
Old Dec 27, 2013 | 01:30 PM
buba6's Avatar
buba6
By the way my starter has 11 teeth
Old Dec 30, 2013 | 01:59 PM
buba6's Avatar
buba6
any info?
Old Dec 30, 2013 | 02:52 PM
Paul L's Avatar
Paul L
Originally Posted by buba6
any info?
I'll try this one. This is a new starter in my basement inventory for a 1974 350 with automatic transmission. This unit should be common 1970 through 1982. The manual transmission cars apparently take a different unit although I do not know what the difference between auto and manual starters is. I count nine (9) teeth on the Bendix. The part reference is Remy International #96122.
Old Dec 30, 2013 | 03:13 PM
lvmyvt76's Avatar
lvmyvt76
where did you buy the starters????? any help from them on the problem???
Old Dec 30, 2013 | 03:18 PM
Paul L's Avatar
Paul L
Good point! I have never seen the internals of a starter fall apart after a couple of starts. Surely the vendor will have something to say to the buyer.
Old Dec 30, 2013 | 03:20 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by paul 74
...automatic transmission....The manual transmission cars apparently take a different unit...
Yep. 4 speed and AT starters are differnet because the flywheels have a different number of teeth on them. Starter must match the flywheel.
Old Dec 30, 2013 | 03:34 PM
damoroso's Avatar
damoroso
If you're sure the engine and flywheel is stock, you should be able to order the correct starter. If not, you have to know the number of teeth on the flywheel and order the starter from that.
Old Dec 30, 2013 | 03:41 PM
don hall's Avatar
don hall
Besides the matching teeth, the starter motor must be aligned
correctly. You may need shims to correct alignment.
The info in this link may help:
http://forums.corvetteforum.com/c3-t...w-starter.html
Old Dec 30, 2013 | 03:44 PM
Paul L's Avatar
Paul L
Thanks for that clarification! We don't know what transmission the OP has but possibly he has bought, or been supplied, mis-matched starters?
Old Dec 30, 2013 | 04:58 PM
buba6's Avatar
buba6
I have a stock th350
Old Dec 30, 2013 | 05:27 PM
diehrd's Avatar
diehrd
What do you mean rattle and they are broken ,Do you mean the nose cone ?
Old Dec 30, 2013 | 05:31 PM
Ironcross's Avatar
Ironcross
I would suggest for you to use the starter with the cast iron nose.....The only difference is the nose, the internals are the same.....
Why is this thread 3 years old? or did I miss read it
Old Dec 30, 2013 | 05:33 PM
diehrd's Avatar
diehrd
Ya 12 27 2013
Old Dec 30, 2013 | 05:54 PM
Paul L's Avatar
Paul L
Three days.
To Corvette starter details - constant problems
