*Dream Engine Build Thread*
Old Dec 30, 2013 | 05:54 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default *Dream Engine Build Thread*
What would you build if you had unlimited funds and wanted to build a GEN I Chevy engine
It can be small block or big block
No LS
Power Adders OK.
List all of the parts you would use. GO!
Les
Old Dec 30, 2013 | 07:59 PM
TimAT's Avatar
TimAT
Aluminum 4.6 bore block 55mm cam tunnel
Bryant Billet crank 4.25 stoke
Oliver rods
AFR Heads
Just to start..
Old Dec 30, 2013 | 09:25 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Oliver rods
AFR Heads
Just to start..
Na Tim.......Dart 355 CNC Heads!!!!
Old Dec 30, 2013 | 09:28 PM
tfi racing's Avatar
tfi racing
An 850 HP ex-Nascar SB2 SBC would do the trick,you can buy them all day now for way less than $10K...
Old Dec 30, 2013 | 11:15 PM
bluedawg's Avatar
bluedawg
A procharged 572.
Old Dec 30, 2013 | 11:30 PM
cv67's Avatar
cv67
St. Jude Donor '05
Big CI SB2.2
Sometimes get the itch for a 565 but cant get it to the ground anyway so whats the use
Old Dec 31, 2013 | 12:54 AM
C3 Stroker's Avatar
C3 Stroker
This one.....http://www.ultrastreet.net/engines/5...wg_twisted.php.
598" Street Engine, 920hp
Old Dec 31, 2013 | 01:16 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I am a small block guy. My dream engine is a 427 with 8 stack Inglese EFI. It has a Brodix A-356 Aluminum block, 350 mains, Splayed 4 bolt billet steel main caps, with raised cam. Sonny Bryant 4" stroke lightweight billet crank, Oliver rods and Mahle low expansion forged pistons, It has AFR 227 Heads with Jesel shaft rockers, It is running 12 to 1 compression and a solid roller, puts out over 700 HP runs on on pump gas and has an 8000 RPM redline with peak HP @ 7500. Revs fast and weighs about #300. It would be in my 63 in front of my Chevy Viper T56 6 speed and Tom's 12 bolt 4.11.
Old Dec 31, 2013 | 07:53 AM
Gordonm's Avatar
Gordonm
Twin turbo big cube SB. Turbos can make insane HP and still be drive able.
Old Dec 31, 2013 | 09:57 AM
cv67's Avatar
cv67
St. Jude Donor '05
Shouldnt have clicked on C3s link. Wow thats a ton of power for the money!
Old Dec 31, 2013 | 10:04 AM
73C34me's Avatar
73C34me
I have one of "these" too!
Old Dec 31, 2013 | 10:31 AM
uxojerry's Avatar
uxojerry
BBC 532 with Brodix SR20 heads, set up for pump gas and designed to spin above 7500rpm. Should make the torque low enough for a T56 but make near 1000hp. 4" stroke by 4.6" bore.
Old Dec 31, 2013 | 10:53 AM
AGVI's Avatar
AGVI
I love that website. I would for for this http://www.ultrastreet.net/engines/5...wg_lowdeck.php
Old Dec 31, 2013 | 11:38 AM
billla's Avatar
billla
St. Jude Donor '14
+1 for the SBC club I had my ZL-1 dreams and carted around a block for years...but every time I did the math it was clear that I just couldn't make it happen. That's about the time my last '69 went on the truck
Engine Masters highlighted a build a few years ago of an all-aluminum 350 making over 700 HP. I did something a little less wild that would be my dream-build. I don't have all the parts laid out, but I'd stick with 350 CID and shoot for around 600 HP at the crank.
Old Dec 31, 2013 | 11:56 AM
cv67's Avatar
cv67
St. Jude Donor '05
Like to hear your build plans for that one Billa
love high winding small blocks my last 350 should have crested the 550 mark or close there was just too much wrong with a few things. Once torn down just put a bigger crank in it.
Old Jan 1, 2014 | 12:09 PM
63mako's Avatar
63mako
Those are sweet. Think he uses 4340 forged Eagle rotators on a lot of his builds which is the only real downside but if they measure and spec good it is not a big deal.
Old Jan 1, 2014 | 06:22 PM
MrForce's Avatar
MrForce
St. Jude Donor '11, '14
I would call Tom Nelson and order one of these
To *Dream Engine Build Thread*
Old Jan 3, 2014 | 10:56 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Kinda like eating a Lays potato chip: you can't have just one.
All of my experience has been with Gen 1 SBC and I've been itchin' to lay hands on a BBC package to put in my C3.
The AX racer in me says stick with the small block and go turbo. The illegal street racer in me says Big Inches, Baby.
To answer AGVI's question here, I'd go with that 775 horse Shafiroff motor. I've been one of his fans for decades and would love to show off one his engines when I raise the hood.
Old Jan 3, 2014 | 11:02 AM
63mako's Avatar
63mako
They have a 920 HP hydraulic roller pump gas version available with a Callies Magnum Plus crank and Oliver rods as well.
http://www.ultrastreet.net/engines/5..._twistedhr.php
Old Jan 3, 2014 | 11:06 AM
diehrd's Avatar
diehrd
EXACTLY ,,,,,,,,, No one else comes close to NRE
