LS3 startup with open headers
Old Jan 2, 2014 | 12:41 PM
Gordonm's Avatar
Gordonm
Default LS3 startup with open headers
Not sure if this will work. Not great on the computer. I started the LS3 up with the open cut off headers I had. These are not the AR headers I have been working on but the cut up Melrose headers just so I can run and move the car. Short 28 second video.
Seems to work. This was done with my Ipad so the sound is not great.
Old Jan 2, 2014 | 12:46 PM
Shark Racer's Avatar
Shark Racer
Looks beautiful, sounds like it could suck up a small to medium-sized child. Nice to see and hear it!
Old Jan 2, 2014 | 07:13 PM
CWerner's Avatar
CWerner
Sweet
Old Jan 2, 2014 | 08:09 PM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Awesome! Jealous!! Wish I was at that point
Old Jan 2, 2014 | 09:06 PM
myko's Avatar
myko
Wow! Hmm... yeah, WOW! I'm definitely jealous, too.
Old Jan 2, 2014 | 10:19 PM
CWerner's Avatar
CWerner
I don't recall seeing your air intake setup in your build thread. More details needed
Old Jan 2, 2014 | 10:37 PM
Gordonm's Avatar
Gordonm
There really is nothing yet. I just cut up an air bridge so I could mount the MAF. Sensor. That is one of my major projects.. I'd love to make an over the radiator support system but with the hood opening the way it does it is tough. May just put In a 90 degree setup for the time being but as you can see there is no room for an air filter setup with the current setup. I'm working on it though.
Old Jan 2, 2014 | 11:12 PM
garygnu's Avatar
garygnu
was the ECM tuned for those injectors ?
Old Jan 3, 2014 | 06:14 AM
Gordonm's Avatar
Gordonm
Right now it is not running properly. No O2 sensors installed but it has the stock injectors and I am using the computer that came with the 09 Vette the motor came from. It has had all the emissions and Vats taken out but certainly not fine tuned yet. It runs well enough to move under its own power but not road drive able yet.
Old Jan 3, 2014 | 07:29 AM
myko's Avatar
myko
Where did you send the ECU to be flashed? I have the Corvette exhaust manifolds and am making my own exhaust to I am wondering if I can or plan to leave one or both sets of O2 sensors in the system?
Old Jan 3, 2014 | 07:35 AM
Gordonm's Avatar
Gordonm
I got the wiring harness and had PSI do this. They removed the Vats and just put in a preliminary tune to get it running. I am only using one set of o2 sensors as this is all that is needed when not running the cats.
Old Jan 3, 2014 | 12:33 PM
Shark Racer
Rear O2 sensors are there to determine whether or not the catalytic converters are operating correctly. No cats, no need for rear O2s.
Old Jan 3, 2014 | 12:44 PM
1977L48's Avatar
1977L48
it sounds like a cougar, the animal not the car, "time to set the cougar loose"
Old Jan 3, 2014 | 03:25 PM
DZRick's Avatar
DZRick
Old Jan 3, 2014 | 08:57 PM
gkull's Avatar
gkull
Gordon, the choice of LS3 is a good one. With long tube headers you have a good 450 hp
Old Jan 3, 2014 | 09:00 PM
Gordonm's Avatar
Gordonm
Also have a cam change to a more aggressive cam and I will have a tune on the computer. Looking for 500 Hp. Later on down the road maybe a little head work.
Old Jan 3, 2014 | 10:36 PM
gkull's Avatar
gkull
actually the local race shop told me that those 2008 and later ls3 heads are good as is to about 600 hp. In stock form the valve weight and spring combo limits them to 6600 rpm. Some people go to the biggest BeeHive springs that Comp Cams sells and then they spin them to 7500.
To LS3 startup with open headers
Old Jan 3, 2014 | 11:13 PM
Shark Racer
Ported LS3s are all the rage in budget builds... for the price of a pair of cheap AFRs you can have heads flowing 350cfm.
Old Jan 3, 2014 | 11:52 PM
Lupigiato's Avatar
Lupigiato
Sounds louder than mine - LOL!
Old Jan 4, 2014 | 08:29 AM
Gordonm's Avatar
Gordonm
The cam is only 223/231 @ .050 so it does not need to be wound up very high. I did upgrade the springs to what Comp cams said to upgrade to. They Are beehive springs. I should not need to go over 65000 rpm for max power with this combo. Thinking of porting or changing the intake and throttle body for a little extra HP.
