I have been making good progress without too major of hiccups, BUT...
I put in the carpet yesterday so today I started the rear trim right behind the driver seat.
I cannot seem to get the trim aligned to the edge of the pillar and the weather stripping. Also the metal trim that attaches to the inside trim is a pain in the a$$, in particular the curved piece at the top.
the trim and metal are after market. I had to adjust the angled slots some, but not much since the spacing of the screw holes was not exactly as it use to be.
The curved trim has a wavy side which will not follow the curve of the car.
Can I see pics of that area so I can see how the metal is aligned and would like to see the edge of the inside trim. Also any help, suggestions would be appreciated.
I need to see the metal trim that is below the weather stripping, where the door latches, and how the trim aligns on the edge (at the edge of the door window and right behind the seat).
basically a pic of the rear quarter panel and rear quarter panel retainer
The metal pieces go on the outside.
#1 the inside trim has the nuts molded in to it.
It lines up with the slots in the fiberglass body.
8 & 9 attach from the outside and hold everything in place.
The screws are 6 X 32 by 1/2 or 3/8.
#8 goes on first and make sure the metal trim piece with the 3 holes line up with the inside trim piece first as some replacements are made with the center hole was off.
do you have a pic of the fit of the trim to the right/left of the weather strip right above the pics you posted? I am trying to see what the gap line looks like, that is the part the seams to be throwing me off.
#8 seems to push the inside trim away from the bottom of the weather strip, and it is tighter at the top of that weather strip.
btw , looks like you had the same color scheme my 72 had originally. it is now blue (not white) and dark saddle.
FWIW, I have had my 1/4 trim retainers off and on numerous times. In my opinion, the screws are too short, which causes much difficulty in getting them to engage in the nutserts molded into the retainer when installing in place.
I have had greater success when pre-assembling the retainers to the 1/4 trim itself, leaving the screws as loose as possible, then sliding the assembly into place. Once I have the trim and the retainer pieces straddling fiberglass body section, I hold in position with one hand while tightening with my other 3 hands . Actually, I sometimes get help from my wife, having her hold the pieces in place while I tighten the screws.
I have been able to get them on and did it similarly, but the gap seemed too wide at the weather stripping, It was nice at the top and widened at the bottom of the weather strip.
Down the length of the panel, the gap looked ok next to the long retaining strip. I hade to widen the middle slot for the long retainer for that to line up so I could screw it. the top eyelet just seems to be too far from the edge and as such I cant push that part in any further.
You may have to bend those aftermarket pieces some to minimize the gaps....prior to inserting the screws. There should not be much stress on those screws after installation. Otherwise, over time, the inserts will just pull out.
Hi ef,
In your first post you asked about the 'wave' in the top piece... it's really doesn't match the shape of the lock pillar fiberglass.
Here's a couple of pictures that may help you with fitting yours.
Good Luck!
Regards,
Alan
thanks alan, I see even at the bottom of your weather stip it is a small gap to the edge of the trim.
Here are pics of mine which shows my issue.
Notice the trim aligns pretty nicely (this is of course without the curved piece)
The last pic shows the issue, the screw "hole" in the interior quarter panel, sits way at the back of that groove. I even lengthened it to get it to even show. The curved retainer will not align with that hole, even when I "modified" the curved piece.
they all are laying in there so I don't step on it. the is not the one I am trying to fit good eye, didn't even tee that in the back ground.
the screw hole is right about the back of the door pillar no way the retainer screw hole will line up.
I just finished doing this same job on my 69 interior. I bought a screw pac from a forum vendor and saw that the originals were longer...
Install the curved top piece first but don't tighten it down. Then install the long piece. Tighten the two bottom screws, then tighten the screw on the short piece. Then install the second screw that holds the top of the long piece over the short one and tighten it. Four screws total and you should be good to go Also, the threaded plugs sometimes pull out of the trim so use two part epoxy to re-set it and a small thin washer set in the epoxy between the inside trim piece and the body so it won't pull through again.
I decided to add an eyelet to the inside trim piece that the curved retainer will screw into.
After getting the fit I needed with the interior trim in place with the long retainer locked down. The original screw point in the trim piece was way way too far back and sitting above the edge of the pillar which means the curved retainer would not be able to be screwed into it.
I placed the curved retainer in, marked where the alignment should be, then added an eyelet where it should be. I too and cut an eyelet mount out of the old broken trim piece, ground it to fit and epoxied it where it should go. it will be ready to try this afternoon. It should be a nice fit.
Reason: pic added
Ingenuity is indeed the mother of invention! I dig reading how people overcome problems. It's the passion that can only be described as being "in the blood" that drives us forward, eagerly anticipating the next challenge our Corvette ladies bring to the table, which undoubtedly WILL happen. And since it's my first Vette and I'm only at the gutted interior stage, I presume there is still a bag full of "what do I do now's" waiting for me before my project gets anywhere near completed...
it is fun figuring it out, and hoping the solution works, I will find that out later today, and still not sure if the passenger side will fight me also.
I do wish OFTEN that there was more room to work inside the car. My next build will be a BIG A** Muscle Car lol
Thanks for starting the post and all the replies. It is helping me with my 72 BB restoration.
Got it done finally. Before I moved the eylet, I measured it. So today I decided to measure the location of the eyelet on the passenger side panel. that one looks like it is much better aligned than the driver side. AND it was 1/4 (maybe a lil shy) closer to the edge of the trim piece. so the position of that driver eyelet was the issue, not the retainer (I still think the shape is wrong but I am not the designer of that part)
