Share Your C3 Upgraded Wheel/Tire Combo's
Old 06-12-2016, 07:21 PM
  #541
FKING1
FKING1's Avatar
I have 18x9.5 with 5.5 BS and 1/4" spacers. 275 rr & 255 frt.
As I autocross put max negative camber to clear lowered rear springs.
Have to relocate both emergency brackets.
jpattt24 (06-12-2016)
Old 06-12-2016, 11:50 PM
  #542
jpattt24
jpattt24's Avatar
ok made my final decision. I'm going with 18x9.5 4 3/4" backspacing. I am thinking my wheel will be 3/4" less on the outside. than this car in pic below running a 18x10 with a 4.5" backspacing. what do yall think ??
Old 06-13-2016, 12:58 AM
  #543
jpattt24
jpattt24's Avatar
This is my car now with 15x8 4" backspacing. 235/60/15 tires will post pics with tt 2s wheels when they come in.
Old 06-13-2016, 11:41 AM
  #544
jpattt24
jpattt24's Avatar
Has anyone ordered custom TT 2 wheels from wheels for less.com website states 4-6 weeks just wondering how long it took for some of you to receive yours ?? thanks
Old 06-13-2016, 02:54 PM
  #545
79 C3
79 C3's Avatar
Sweet Car
jpattt24 (06-13-2016)
Old 06-13-2016, 07:55 PM
  #546
resdoggie
Had a 1976 L-82, 4-sp
Support Corvetteforum!
resdoggie's Avatar
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes on 925 Posts
Royal Canadian Navy
I have US Mags Ramblers. 18x8 4.5 BS on front and 18x9.5 5.25 BS rear. 275's rear, 245's front. Although I relocated the parking brake bracket, I don't think that it was required for clearance but the cable would have needed a tie strap or two to make room. No interference with spring bolts, calipers, rear spring end or sway bar end links and no spacer. I did use a 1/4" spacer on the fronts to move the wheels outboard.
landdog1 (09-08-2017)
Old 06-13-2016, 09:26 PM
  #547
jpattt24
jpattt24's Avatar
So I'm thinking with my 18x9.5 with a 4 3/4" backspacing. will be 3/4" further out toward the fender well lip than yours. I think I will be fine with that.
Old 06-13-2016, 09:43 PM
  #548
68sting
68sting's Avatar
Rear 18x10, 5.5" back spacing, 1/4" spacers and 285/40/18. Front is 17x8, 4" back spacing and 245/45/17.
Darth Z (05-21-2017)
Old 06-13-2016, 10:09 PM
  #549
3JsVette
3JsVette's Avatar
Received 2,491 Likes on 1,645 Posts
Originally Posted by 68sting
Rear 18x10, 5.5" back spacing, 1/4" spacers and 285/40/18. Front is 18x8, 4" back spacing and 245/45/17.
Nice color and stance too!
Old 06-13-2016, 10:38 PM
  #550
68sting
68sting's Avatar
Thanks. I need to change something after hitting a pothole though.😥
Old 06-14-2016, 07:55 AM
  #551
resdoggie
resdoggie's Avatar
Royal Canadian Navy
You shouldn't have any clearance issues with that BS.
jpattt24 (06-14-2016)
Old 06-14-2016, 11:09 PM
  #552
3JsVette
3JsVette's Avatar
Ouch! Sorry to see that. Did you need that 1/4" spacer? Maybe a little too much tire? You may have to adjust rear ride height or think about a 275 tire.
Old 06-16-2016, 09:07 PM
  #553
68sting
68sting's Avatar
I need to get a shorter spring in order to remove the 1/4" spacers. Not sure exactly what I need to do yet. Maybe some mild flares.
Old 06-17-2016, 07:44 AM
  #554
BLUE1972
BLUE1972's Avatar
Received 1,130 Likes on 733 Posts
Did you look at off-set trailing arms. that may help.
Old 06-17-2016, 11:42 AM
  #555
Street Shaker
Street Shaker's Avatar
You need taller bumps stops and your problem will be solved. Install taller bump stops or re modify mounting tabs for your existing stock ones and you will have no issues. You can get taller Bump stops from Jegs.com they have 1 1/2" or 2" tall. Had same issue and this fixed it.
Offset trailing arms will not change anything with existing rims.
Paja
Old 06-19-2016, 12:51 AM
  #556
GregS_72
GregS_72's Avatar
Location: St Louis MO http://1972corvetterestomod.blogspot.com/
FRONT
18x8 American Racing Polished Torq-Thrust II wheels, 4" backspacing, 245/45/18 Nitto NT555 tires.
REAR
18x9.5 American Racing Polished Torq-Thrust II wheels, 5" backspacing, 285/40/18 Nitto NT555 tires.
Stock trailing arms. VB&P Performance Plus rear suspension package but with stock rear sway bar. All pics are with the body off the frame since that is where the project is at right now. All fit OK, but I'll have some close spots to monitor on the rear when she's done.
jpattt24 (06-29-2016)
Old 06-28-2016, 09:40 PM
  #557
Oldguard 7
Oldguard 7's Avatar
It seems as though every c3 corvette has TT2 aftermarket wheels and the cars all seem the same. I have looked at past threads (as far back as 2002) and I see TT2s then. Can anyone tell me the reason they are so popular?
To Share Your C3 Upgraded Wheel/Tire Combo's
Old 06-28-2016, 09:54 PM
  #558
Metalhead140
Metalhead140's Avatar
C3 of Year Finalist (track prepared) 2019
'cos they look great! I know what you mean though. Seems to be the case that most cars though end up with a most common aftermarket wheel associated with them.
Old 06-29-2016, 10:53 AM
  #559
jpattt24
jpattt24's Avatar
Because they look Awesome on C3's I live in savannah ,Ga and never have seen any vette with tt 2's on it on the street. I have tt 2's ordered now for my 71.. so there will be one more out there!
Old 06-29-2016, 11:00 AM
  #560
jpattt24
jpattt24's Avatar
Got the 2 front rims and 4-tires. now waiting on the custom offset rear rims!
Quick Reply: Share Your C3 Upgraded Wheel/Tire Combo's
